程序可以进入中断但是在中断程序中一直执行打印语句,不能跳出中断,在中断中我已将srcpnd和intpnd写1清除,我怀疑是
; Setup IRQ handler
ldr r0,=HandleIRQ ;This routine is needed
;ldr r1,=IsrIRQ ;if there is not 'subs pc,lr,#4' at 0x18, 0x1c
ldr r1, =OS_CPU_IRQ_ISR ;for ucos
str r1,[r0]
中的OS_CPU_IRQ_ISR宏出了问题,才导致中断无法退出,可又不知是什么问题
请高手指点 不胜感激!!!
OS_CPU_IRQ_ISR
STMFD SP!, {R1-R3} ; We will use R1-R3 as temporary registers
; R1--SP
; R2--PC
; R3--SPSR
MOV R1, SP
ADD SP, SP, #12 ;Adjust IRQ stack pointer
SUB R2, LR, #4 ;Adjust PC for return address to task
MRS R3, SPSR ; Copy SPSR (Task CPSR)
MSR CPSR_cxsf, #SVCMODE|NOINT ;Change to SVC mode
; SAVE TASK''S CONTEXT ONTO OLD TASK''S STACK
STMFD SP!, {R2} ; Push task''s PC
STMFD SP!, {R4-R12, LR} ; Push task''s LR,R12-R4
LDMFD R1!, {R4-R6} ; Load Task''s R1-R3 from IRQ stack
STMFD SP!, {R4-R6} ; Push Task''s R1-R3 to SVC stack
STMFD SP!, {R0} ; Push Task''s R0 to SVC stack
STMFD SP!, {R3} ; Push task''s CPSR
LDR R0,=OSIntNesting ;OSIntNesting++
LDRB R1,[R0]
ADD R1,R1,#1
STRB R1,[R0]
CMP R1,#1 ;if(OSIntNesting==1){
BNE %F1
LDR R4,=OSTCBCur ;OSTCBHighRdy->OSTCBStkPtr=SP;
LDR R5,[R4]
STR SP,[R5] ;}
MSR CPSR_c,#IRQMODE|NOINT ;Change to IRQ mode to use IRQ stack to handle interrupt
LDR R0, =INTOFFSET
LDR R0, [R0]
LDR R1, IRQIsrVect
MOV LR, PC ; Save LR befor jump to the C function we need return back
LDR PC, [R1, R0, LSL #2] ; Call OS_CPU_IRQ_ISR_handler();
MSR CPSR_c,#SVCMODE|NOINT ;Change to SVC mode
BL OSIntExit ;Call OSIntExit
LDMFD SP!,{R4} ;POP the task''s CPSR
MSR SPSR_cxsf,R4
LDMFD SP!,{R0-R12,LR,PC}^ ;POP new Task''s context
IRQIsrVect DCD HandleEINT0
