注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
mcy_cool的个人空间 https://home.eeworld.com.cn/space-uid-320632.html [收藏] [复制] [分享] [RSS]
日志
arduino平台的点阵驱动程序设计
已有 7936 次阅读2012-12-20 15:54 |
硬件平台:
1、CooCox官方推出的Cookie板,该板基于32位ARM Cortex M0/3/4 MCU,完全兼容arduino,同时更加丰富了其接口功能。
2、基于arduino平台的8*8点阵,驱动芯片是DM163。
软件平台:
1、CooCox推出的CoIDE编译器。
2、CooCox推出的针对M3和M0内核CPU的固件库CoX,该固件库使用比较简单,接口设计的非常合理,比如设置某一个模块只需一个函数,降低了入门的难度,详细情况可以访问CooCox官网了解。
下面附上相关的主要程序:
#include "xhw_types.h"
#include "xcore.h"
#include "xhw_ints.h"
#include "xhw_memmap.h"
#include "xhw_nvic.h"
#include "xhw_sysctl.h"
#include "xhw_gpio.h"
#include "xdebug.h"
#include "xsysctl.h"
#include "xgpio.h"
#include "xhw_timer.h"
#include "xtimer.h"
#include "coshining.h"
#include "coshining_cfg.h"
#include "Dot_Matrix.h"
//! Define the data zone
//! Gamma correctly value, every LED plane is different.value range is 0~63
//! [3]:RGB data, 0 for Red; 1 for green, 2 for Blue
static unsigned char g_ucGammaValue[3] = {10,63,63};
//! the index of buffer
static unsigned char g_ucPageIndex = 0;
static unsigned char g_ucLine = 0;
//! Test dots
//!dots matrix
//![2]:Page:one for display, one for receive data
//![8]:Row:8 row in LED plane
//![8]:Column:8 column in one row
//![3]:Color:RGB data: 0 for Red; 1 for green, 2 for Blue
static unsigned char dots[2][8][8][3] = {0};
#define open_line0 {xGPIOSPinWrite(sD8,1);}
#define open_line1 {xGPIOSPinWrite(sD9,1);}
#define open_line2 {xGPIOSPinWrite(sD10,1);}
#define open_line3 {xGPIOSPinWrite(sD11,1);}
#define open_line4 {xGPIOSPinWrite(sD12,1);}
#define open_line5 {xGPIOSPinWrite(sD13,1);}
#define open_line6 {xGPIOSPinWrite(sD3,1);}
#define open_line7 {xGPIOSPinWrite(sD4,1);}
#define close_all_line {xGPIOSPinWrite(sD8,0);xGPIOSPinWrite(sD9,0);   \
                         xGPIOSPinWrite(sD10,0);xGPIOSPinWrite(sD11,0); \
                         xGPIOSPinWrite(sD12,0);xGPIOSPinWrite(sD13,0); \
                         xGPIOSPinWrite(sD3,0);xGPIOSPinWrite(sD4,0);}
//! \brief Init the DM163 Control connected pin
//! \note The data will parral out.
//! \return None.
void
DM163PinInit(void)
    xSysCtlPeripheralEnable(xSYSCTL_PERIPH_GPIOA);
    xSysCtlPeripheralEnable(xSYSCTL_PERIPH_GPIOB);
    xSysCtlPeripheralEnable(xSYSCTL_PERIPH_GPIOC);
    xSysCtlPeripheralEnable(xSYSCTL_PERIPH_GPIOE);
    // Set PD4(DIR_SDA), PD5(DIR_SCL), and PB0(DIR_SB) PB1(DIR_LATCH) PB2(DIR_RST) as output
    xGPIOSPinTypeGPIOOutput(sD6);   // SCK
    xGPIOSPinTypeGPIOOutput(sD7);   // SDA
    xGPIOSPinTypeGPIOOutput(sA0);   // SB
    xGPIOSPinTypeGPIOOutput(sA1);   // LATCH
    xGPIOSPinTypeGPIOOutput(sA2);   // RST
    // Disable the output, data serial in and latch register.
    xGPIOSPinWrite(sA2, 1);
    xSysCtlDelay(100);
    xGPIOSPinWrite(sA2, 0);
    xSysCtlDelay(100);
    xGPIOSPinWrite(sA0, 1);
    xGPIOSPinWrite(sA1, 0);
//! \brief Write data to DM163.
//! \param ucData is the serial in data.
//! \return None.
void
DotMatrixSetGamma(void)
    unsigned char ucData, i, j, k;
    // 6 bit image data
    xGPIOSPinWrite(sA0, 0);
    // Serial data in
    for(i = 0; i < 8; i++)
        for(j = 3; j > 0; j--)
            ucData = g_ucGammaValue[j-1]<<2;
            for(k = 0; k < 6; k++)
                if(ucData & 0x80)
                    xGPIOSPinWrite(sD7, 1);
                else
                    xGPIOSPinWrite(sD7, 0);
                ucData = ucData << 1;
                xGPIOSPinWrite(sD6, 0);
                xGPIOSPinWrite(sD6, 1);
//! \brief Write data in the corresponding row and select it.
//! \param ucRow is the row number in LED plane, range 0 to 7.
//! \note None.
//! \return None.
void
DotMatrixRunRow(unsigned char ucRow)
    unsigned char i, j, p, ucData;
    // 8 bit image data
        for(j = 0; j < 3; j++)
            ucData = dots[g_ucPageIndex][ucRow][i][2-j];
            for(p = 0; p < 8; p++)
             if(ucData & 0x80)
                else
    xGPIOSPinWrite(sA1, 1);
//! \brief Select the corresponding row.
//! \param ucLine is line num range 0 to 7.
//! \return None.
void
DotMatrixOpenLine(unsigned char ucLine)
    switch (ucLine)
      case 0 :open_line0;
            break;
      case 1 :open_line1;
            break;
      case 2 :open_line2;
            break;
      case 3 :open_line3;
            break;
      case 4 :open_line4;
            break;
      case 5 :open_line5;
            break;
      case 6 :open_line6;
            break;
      case 7 :open_line7;
            break;
      default: close_all_line;
            break;
#include "font.h"
unsigned char
pgm_read_byte(unsigned char *s)
    return *s;
//! \brief Show the four-dimensional arrays in LED matrix.
//! \param None.
//! \return None.
void
DotMatrixRunArray(void)
    if(g_ucLine > 7) g_ucLine = 0;
    close_all_line;
    DotMatrixRunRow(g_ucLine);
    DotMatrixOpenLine(g_ucLine);
    g_ucLine++;
//! \brief Show a English latter in LED matrix.
//! \param ch is the latter want to show.
//! \param R is the value of RED,   Range:RED 0~255.
//! \param G is the value of GREEN, Range:RED 0~255.
//! \param B is the value of BLUE,  Range:RED 0~255.
//! \param Bias is the bias of a letter in LED Matrix, Range -7~7.
//! \return None.
void
DotMatrixShowChar(char ch, unsigned char R, unsigned char G, unsigned char B, long lBias)
    unsigned char i, j, Page_Write, ucData;
    unsigned char chrtemp[24] = {0};
    xASSERT((lBias > -8) && (lBias < 8));
    if ((lBias > 8) || (lBias < -8))
        return;
    if(g_ucPageIndex == 0)
        Page_Write = 1;
    if(g_ucPageIndex == 1)
        Page_Write = 0;
    j = 8 - lBias;
    for(i = 0; i< 8; i++)
        chrtemp[j] = pgm_read_byte(&(font8_8[ch - 32][i]));
        j++;
     ucData = chrtemp[i+8];
        for(j = 0; j < 8; j++)
            if(ucData & 0x80)
                dots[Page_Write][j][i][0] = B;
                dots[Page_Write][j][i][1] = G;
                dots[Page_Write][j][i][2] = R;
            else
                dots[Page_Write][j][i][0] = 0;
                dots[Page_Write][j][i][1] = 0;
                dots[Page_Write][j][i][2] = 0;
    g_ucPageIndex = Page_Write;
//! !brief callback function of TIMER interrupt handler.
//! \return None.
unsigned long
DotMatrixScan(void *pvCBData,  unsigned long ulEvent,
               unsigned long ulMsgParam,
               void *pvMsgData)
 DotMatrixRunArray();
 return 0;
//! \brief Configure scanning duty cycle.
//! \param ulSrcFreq is the timer clock source.
//! \param ulScanFerq(ms) is the scanning duty cycle.
//! \return None.
void
DotMatrixScanTimerInit(unsigned long ulSrcFreq, unsigned long ulScanFerq)
    unsigned long ulMatchVal = (ulSrcFreq * DM_SCAN_FREQ) / (DM_SCANDIV_VALUE * (DM_SCANPSR_VALUE + 1) * 1000);
    // Set the timer clock
    xSysCtlPeripheralClockSourceSet(DM_SCAN_CLKSRC, DM_SCANDIV_VALUE);
    xSysCtlPeripheralEnable2(DM_SCAN_TIMER);
    // Clear the status first
    TimerIntClear(DM_SCAN_TIMER, xTIMER_INT_MATCH);
    while(xTimerStatusGet(DM_SCAN_TIMER, DM_SCAN_CHANNEL, xTIMER_INT_MATCH));
    // Config as periodic mode
    xTimerInitConfig(DM_SCAN_TIMER, DM_SCAN_CHANNEL, xTIMER_MODE_PERIODIC, ulScanFerq);
    xTimerPrescaleSet(DM_SCAN_TIMER, DM_SCAN_CHANNEL, DM_SCANPSR_VALUE);
    xTimerMatchSet(DM_SCAN_TIMER, DM_SCAN_CHANNEL, ulMatchVal);
    xTimerIntEnable(DM_SCAN_TIMER, DM_SCAN_CHANNEL, xTIMER_INT_MATCH);
    xTimerIntCallbackInit(DM_SCAN_TIMER, DotMatrixScan);
    xIntEnable(xSysCtlPeripheralIntNumGet(DM_SCAN_TIMER));
    // Start the timer
    xTimerStart(DM_SCAN_TIMER, DM_SCAN_CHANNEL);
下面附一些开发的效果图:
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
