注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
breeze_i的个人空间 https://home.eeworld.com.cn/space-uid-1492951.html [收藏] [复制] [分享] [RSS]
日志
【Follow me第二季第3期】进阶任务:示例程序中新增命令打印信息
已有 294 次阅读2024-12-15 23:23 |个人分类:RA6M5
 本次任务是进阶任务:示例程序中新增命令打印信息。
 在memu_main.c中修改s_menu_items菜单数组。添加,Hello Information,对应函数为hello_display_menu。
/* Table of menu functions */
static st_menu_fn_tbl_t s_menu_items[] =
    {"Hello Information"                       , hello_display_menu},
    {"Kit Information"                         , kis_display_menu},
    {"Web Server"                              , eth_emb_display_menu},
    {"Network Name Lookup"                     , eth_www_display_menu},
    {"Quad-SPI and Octo-SPI Speed Comparison"  , ext_display_menu},
    {"Cryptography and USB High speed (MSC)"   , enc_display_menu},
    {"Next Steps", ns_display_menu },
    {"", NULL }
然后//memu_kis.c文件中新增以下代码
//memu_kis.c
#define HELLO_OPTIONS     "\r\n\x1b[2m\x1b[37m a) FollowMe 2-3 "                                                         \
                        "\r\n\x1b[2m\x1b[37m a) Kit name:                           %s "                               \
                        "\r\n\x1b[2m\x1b[37m b) Kit ordering part number:           %s "                               \
                        "\r\n\x1b[2m\x1b[37m c) RA Device part number:              %s"                                \
                        "\r\n\x1b[2m\x1b[37m d) RA MCU 128-bit Unique ID (hex):     "                                  \
                        "\x1b[32m%08x\x1b[37m-\x1b[32m%08x\x1b[37m-\x1b[32m%08x\x1b[37m-\x1b[32m%08x\x1b[37m"          \
                        "\r\n\x1b[2m\x1b[37m e) RA MCU Die temperature (F/C):       \x1b[32m%d.%02d/%d.%02d\x1b[37m "  \
                        "\r\n\x1b[2m\x1b[37m f) Blue LED blinking frequency (Hz):   \x1b[32m%d\x1b[37m "               \
                        "\r\n\x1b[2m\x1b[37m g) Blue LED blinking intensity (%%%%):   \x1b[32m%d\x1b[37m "
//memu_kis.c
test_fn hello_display_menu(void)
    int8_t c = -1;
    uint16_t wn_mcu_temp_f = 0;
    uint16_t fr_mcu_temp_f = 0;
    uint16_t wn_mcu_temp_c = 0;
    uint16_t fr_mcu_temp_c = 0;
    bsp_unique_id_t const * p_uid = R_BSP_UniqueIdGet ();
    sprintf (s_print_buffer, "%s%s", gp_clear_screen, gp_cursor_home);
    /* ignoring -Wpointer-sign is OK when treating signed char_t array as as unsigned */
    print_to_console((void*)s_print_buffer);
    //sprintf (s_print_buffer, MODULE_NAME, g_selected_menu);
    sprintf (s_print_buffer, "Eeworld and Dgikey is very good", g_selected_menu);
    wn_mcu_temp_f = g_board_status.temperature_f.whole_number;
    fr_mcu_temp_f = g_board_status.temperature_f.mantissa;
    wn_mcu_temp_c = g_board_status.temperature_c.whole_number;
    fr_mcu_temp_c = g_board_status.temperature_c.mantissa;
    sprintf (s_print_buffer, HELLO_OPTIONS, FULL_NAME, PART_NUMBER, DEVICE_NUMBER,
            (int_t)p_uid->unique_id_words[0],  (int_t)p_uid->unique_id_words[1], // typedef uint_t in stdint.h
            (int_t)p_uid->unique_id_words[2],  (int_t)p_uid->unique_id_words[3], // as signed long long int64_t;
            wn_mcu_temp_f, fr_mcu_temp_f, wn_mcu_temp_c, fr_mcu_temp_c,
            g_pwm_rates_data[g_board_status.led_frequency], g_pwm_dcs_data[g_board_status.led_intensity]);
    sprintf (s_print_buffer, MENU_RETURN_INFO);
    /* provide small delay so board_status should be up to date */
    vTaskDelay (s_ticks_to_wait);
    xEventGroupSetBits (g_update_console_event, STATUS_DISPLAY_MENU_KIS);
    while (CONNECTION_ABORT_CRTL != c)
        c = input_from_console ();
        if ((MENU_EXIT_CRTL == c) || (CONNECTION_ABORT_CRTL == c))
            break;
    xEventGroupClearBits (g_update_console_event, STATUS_DISPLAY_MENU_KIS);
    return (0);
编译,下载运行。
可以看到,新增的Eeworld and Dgikey is very good和fellow Me 2-3字样,新增命令成功。
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
