注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
lingmei的个人空间 https://home.eeworld.com.cn/space-uid-59736.html [收藏] [复制] [分享] [RSS]
日志
BGA测试插座,Solderless compression socket
已有 1028 次阅读2010-8-24 11:18 |
Over View
  • Solderless compression type sockets are available for any chip size and grid pattern.
  • Easily mounted to the PCB with 4 through hole mounting pegs.
  • The assembly board ensures perfect coplanarity of the socket.
  • Contact reliability is guaranteed with spring loaded gold plated contacts, which are pressed onto gold plated PCB pads.
  • Solderless compression type sockets are generally supplied with a screw lock retention system.
  • Custom versions available.
Solderless/Compression Type BGA Socket Data Sheet
MECHANICAL DATA
Contact life:
10,000 cycles min.
Retention System life:
10,000 cycles min.
Solderability:
exceeds MIL-STD-202 Method 208
Individual contact force:
40 grams max.
MATERIAL
Insulator (RoHS Compliant):
High temp plastic or epoxy FR4
Terminal (RoHS compliant):
Brass
Contact (RoHS compliant):
BeCu
ELECTRICAL DATA
Contact resistance:
< 100 mΩ
Current rating:
500 mA max.
Insulation resistance
at 500V DC:
100 MΩ if 0.50 to 0.80mm pitch
500 MΩ 1.00mm pitch upwards
Breakdown voltage
at 60 Hz:
500V min.
Capacitance:
< 1 pF
Inductance:
< 2 nH
Operating temperature:
-55°C to +125°C ; 260°C for 60 sec.
全部作者的其他最新日志
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
