注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
kunhubble的个人空间 https://home.eeworld.com.cn/space-uid-560622.html [收藏] [复制] [分享] [RSS]
日志
BQ3050评估板的使用遇到了麻烦
已有 268 次阅读2014-7-7 14:16
问题1:下面使我们遇到的问题的截图, 最后一张是根据数据手册连接两节电池(串联)倒数第二张是评估软件的截图,评估软件显示连接三节电池,实际上我们是2节串联,这是什么原因?
问题2:还有5个LED一直不亮,有时按下按键SW1有个LED会亮一次,但很快熄灭,然后再怎么弄也不亮了
问题3:还有PACK+  PACK-输出端无论加还是不加负载,输出都是为0
The first problem: the following picture are sceeenshots ,which are in 2-series according to our method of connecting wire, however we can see that it is in 3-series from EVSW solftware, actually it is in 2-series ,and why?
The second problem: anyway,whether you connect a load on the PACK side or not  the voltage out between PACK+ and PACK- is also zero under the condition of the circuit conduction, but when we directly use DC POWER to charge the battery pack to active it, DC POWER value is bettew zero and 10V, however, the voltage out is also zero when connect a load.
The third problem: five LEDS are not always light, sometimes, one LED may light when the button SW1 is pressed, but this light LED will quickly go off, then any LED can't be lit  anyway.
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
