library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity key44 is
generic(width: positive :=4);
port(clk :in std_logic;
column : in std_logic_vector(3 downto 0);
row : out std_logic_vector(3 downto 0);
num : out integer range 0 to 15 );
end entity;
architecture beha of key44 is
component key is
din : in std_logic;
dout : out std_logic);
end component;
signal count: std_logic_vector(1 downto 0);
signal row_v,column_v: std_logic_vector(3 downto 0);
signal z : std_logic_vector(5 downto 0);
begin
u1:for i in 0 to width-1 generate
U1: key port map (clk,column(i),column_v(i)); --去抖
end generate;--产生扫描信号
process(clk)
begin
if(rising_edge(clk))then
if(count="11")then
count<="00";
else
count<=count+'1';
end if;
end if;
end process;
row_v <= "1110" when count="00" else
"1101" when count="01" else
"1011" when count="10" else
"0111" ;
row<=row_v;
z<=count&column;
process(clk,z)--译码
begin
case z is
when "001110" => num<=0;
when "001101" => num<=1;
when "001011" => num<=2;
when "000111" => num<=3;
when "011110" => num<=4;
when "011101" => num<=5;
when "011011" => num<=6;
when "010111" => num<=7;
when "101110" => num<=8;
when "101101" => num<=9;
when "101011" => num<=10;
when "100111" => num<=11;
when "111110" => num<=12;
when "111101" => num<=13;
when "111011" => num<=14;
when "110111" => num<=15;
when others => null;
end case;
end if;
end process;
end architecture;
