注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
droidxin的个人空间 https://home.eeworld.com.cn/space-uid-510552.html [收藏] [复制] [分享] [RSS]
日志
笔记之Flash Memory
已有 550 次阅读2013-10-26 14:53 |个人分类:msp430学习笔记|
1.    Flash Memory Segmentaton:
Segment ,mian segment ,information segment
2.    Flash Memory Timing Generator
3.    Erasing Flash Memory
4.    Initiating an Erase from Within Flash Memory:
When a flash segment erase operation is initiated from within flash memory, all timing
is controlled by the flash controller, and the CPU is held while the erase cycle completes.
1th.Disable all interrupt and watchdog
2th.Setup flash controller and erese mode
3th.Dummy write
4th.Set LOCK=1,re-enable interrupts and watchdog
5.  Initiating an Erase from RAM
Any erase cycle may be initiated from RAM. In this case, the CPU is not  held  and can continue to execute code from RAM(CPU无需休眠)
6.  Writing flash memory
7.  Block Write
A block write cannot be initiated from within flash memory. The block write must be initiated from RAM only.
8.  Flash Memory Access During Write or Erase
When any write or any erase operation is initiated from RAM and while
BUSY=1, the CPU may not read or write to or from any flash location.
Otherwise, an access violation occurs
When a byte/word write or any erase operation is initiated from within flash memory, the flash controller returns op-code 03FFFh to the CPU at the next instruction fetch. Op-code 03FFFh is the JMP PC instruction
9.  stopping a Write or Erase Cycle
10. Configuring and Accessing the Flash Memory Controller
11. Flash Memory Controller Interrupts
The flash controller has two interrupt sources, KEYV, and ACCVIFG.
12. Programming Flash Memory Devices
13. Flash Memory Registers
FCTL1,    FCTL2,    FCTL3,    IE1
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
