半个月stm32学习笔记
(三)集GPIO点灯,外部中断查询,串口通讯简单运算器,通用定时器输出PWM波与编码器 源码
#include "stm32f10x.h"
//#include "string.h"
//#include"stdio.h"
变量定义
//int flag,pwmval=600,t;
int encoder_num;
// printf函数的配置
// // 发送数据
//int fputc(int ch, FILE *f)
// USART_SendData(USART1, (unsigned char) ch);// USART1 可以换成 USART2 等
// while (!(USART1->SR & USART_FLAG_TXE));
// return (ch);
// // 接收数据
//int GetKey (void)
// while (!(USART1->SR & USART_FLAG_RXNE));
// return ((int)(USART1->DR & 0x1FF));
外设时钟使能
void RCC_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_USART1 |
RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
/* 使能外设时钟 */
RCC_APB1PeriphClockCmd( RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3|RCC_APB1Periph_TIM4, ENABLE);
全部用到的引脚将在此配置
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;//声明GPIO结构
/*************** USART1的配置 **************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 推挽复用输出
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; // 推挽复用输出
/*********** led灯管脚配置PB12 *************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//管脚的选择
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度的选择
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出模式选择
GPIO_Init(GPIOB, &GPIO_InitStructure);
/***************PWM管脚配置********************/
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 ;
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
// GPIO_Init(GPIOB, &GPIO_InitStructure);
// GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);//设置 TIM3_CH2重映射到PB5上
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;//管脚的选择
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
// GPIO_Init(GPIOA, &GPIO_InitStructure);
/***************外部中断管脚配置********************/
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
/***************按键管脚配置********************/
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//管脚的选择
// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度的选择
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //推挽输出模式选择
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;//管脚的选择
/***************编码器管脚配置********************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
所有中断在此配置
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
// #ifdef VECT_TAB_RAM
// NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);//设置向量表的位置和偏移//向量表在RAM,偏移量为0
// #else
// NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);//向量表在FLASH,偏移量为0
// #endif
/**********串口中断的配置**************/
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0; // 先占优先级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/**********通用定时器4中断配置**************/
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); // 中断分组
// NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;// 中断通道
// NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0; // 先占优先级
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; // 响应优先级
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;// 通道中断使能
// NVIC_Init(&NVIC_InitStructure);//
/**********通用定时器3中断配置**************/
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;// 中断通道
/**********通用定时器2中断配置**************/
// NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;// 中断通道
/**********外部中断配置**************/
// NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;// 中断通道
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; // 响应优先级
// NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;// 中断通道
定时器中断编码器模式在此配置
void TIM3_Encoder_Configuration()//利用定时器3对一个脉冲进行计数
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_ICInitTypeDef TIM_ICInitStructure;
TIM_TimeBaseStructure.TIM_Period = 0xFFFF; ////ARR寄存器得值
TIM_TimeBaseStructure.TIM_Prescaler =0x00; //设置用来作为TIMx时钟频率除数的预分频值
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割0
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
TIM_EncoderInterfaceConfig(TIM3, TIM_EncoderMode_TI1,TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);
//编码模式1 //TI1极性,TIM输入捕获上升沿 //TI2极性
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;//
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;//
TIM_ICStructInit(&TIM_ICInitStructure);
TIM_ICInitStructure.TIM_ICFilter = 0;//输入比较滤波器
TIM_ICInit(TIM3, &TIM_ICInitStructure);
TIM_ETRClockMode1Config(TIM3,TIM_ExtTRGPSC_OFF,TIM_ExtTRGPolarity_NonInverted,0);//
//配置外部时钟模式1,TIM_ExtTRGPSC_OFF//外部时钟触发预分频 ,TIM_ExtTRGPolarity_NonInverted//外部时钟极性。高电平或上升沿有效//不滤波
TIM_SetCounter(TIM3, 0);
TIM_ClearFlag(TIM3, TIM_FLAG_Update);
TIM_ITConfig(TIM3, TIM_IT_Update|TIM_IT_Trigger, ENABLE); //TIM3溢出中断使能
TIM_Cmd(TIM3, ENABLE);
定时器中断精准延时在此配置
//void TIM2_Configuration()
// TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
//// TIM_DeInit(TIM2);//复位TIM3定时器
// //f=72M/(TIM_Prescaler+1)*(1+TIM_Period),
// TIM_TimeBaseStructure.TIM_Period = 999; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值//10ms
// TIM_TimeBaseStructure.TIM_Prescaler =7200-1; //设置用来作为TIMx时钟频率除数的预分频值 7200分频,每100毫秒记1次数
// TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割0
// TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
// TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
// TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
//// TIM_ClearFlag(TIM2, TIM_FLAG_Update);//清除TIM1溢出中断标志
// TIM_ITConfig(TIM2, TIM_IT_Update|TIM_IT_Trigger, ENABLE); //TIM1溢出中断使能
// TIM_Cmd(TIM2, ENABLE); //使能TIM3外设
定时器中断PWM输出在此配置
//void TIM4_PWM_Configuration(u16 Ped,u16 Prr )
// TIM_OCInitTypeDef TIM_OCInitStructure;
// TIM_TimeBaseStructure.TIM_Period = Ped; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值//10ms//ARR寄存器得值
// TIM_TimeBaseStructure.TIM_Prescaler =Prr; //设置用来作为TIMx时钟频率除数的预分频值 7200分频,每100毫秒记1次数
// TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
// TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//TIM脉宽调制模式1
//// TIM_OCInitStructure.TIM_Channel = TIM_Channel_2;//使用TIM通道1
// TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//比较输出使能 比较输出使能 比较输出使能
//// TIM_OCInitStructure.TIM_Pulse = 0;//设置了待装入捕获比较寄存器的脉冲值//CCR寄存器的值
// TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//极性高输出
// TIM_OC1Init(TIM4, & TIM_OCInitStructure);
// TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable); //控制TIM3在OC1上使能预装载寄存器
// TIM_Cmd(TIM4, ENABLE); //使能TIM3外设
USART1 配置函数
void USART1_Configuration(unsigned int baud)
USART_InitTypeDef USART_InitStructure;
USART_ClearITPendingBit(USART1,USART_IT_RXNE);//清除USARTx的中断待处理位
USART_ClearFlag(USART1,USART_FLAG_TC); //清除标志位
USART_InitStructure.USART_BaudRate =baud;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
USART_Init(USART1, &USART_InitStructure);
//// /******同步模式另外需要配置*****/
//// USART_InitStructure.USART_Clock = USART_Clock_Disable;//指定USART时钟使能还是失能
//// USART_InitStructure.USART_CPOL = USART_CPOL_High;//指定了下SLCK引脚上时钟输出的极性
//// USART_InitStructure.USART_CPHA = USART_CPHA_1Edge;//指定了下SLCK引脚上时钟输出的相位,和CPOL位一起配合来产生用户希望的时钟/数据的采样关系
//// USART_InitStructure.USART_LastBit = USART_LastBit_Enable;//控制是否在同步模式下,在SCLK引脚上输出最后发送的那个数据字 (MSB)对应的时钟脉冲
USART_ITConfig(USART1, USART_IT_RXNE , ENABLE);
//// USART_ITConfig(USART1, USART_IT_TXE, ENABLE);//影响进不了中断
USART_Cmd(USART1, ENABLE);
外部中断在此配置
//void EXTI_Configuration()
// EXTI_InitTypeDef EXTI_InitStructure;
// GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);//设置中断口
// EXTI_InitStructure.EXTI_Line = EXTI_Line0 ;
// EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
// EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
// EXTI_InitStructure.EXTI_LineCmd = ENABLE;
// EXTI_Init(&EXTI_InitStructure);
// GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource1);
// EXTI_InitStructure.EXTI_Line = EXTI_Line1 ;
初始化时钟晶振 72MHZ
void SysClock_Init(void)
ErrorStatus HSEStartUpStatus;
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS){
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
FLASH_SetLatency(FLASH_Latency_2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08){
Delay_ms 函数
//void delay_ms(u16 time)
// TIM_SetAutoreload(TIM2, 10*time-1);
// flag=0;
// while(!flag);
按键查询_1 函数
//void keyscan()
// int flag1=0;
// if(flag1==0)
// if(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_0)==RESET)
// GPIO_ResetBits(GPIOB, GPIO_Pin_13);
// GPIO_SetBits(GPIOB, GPIO_Pin_14);
// pwmval=pwmval+1;
// t=pwmval;
// delay_ms(5);
// if(pwmval==1000)
// flag1=1;
// if(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1)==RESET)
// GPIO_SetBits(GPIOB, GPIO_Pin_13);
// GPIO_ResetBits(GPIOB, GPIO_Pin_14);
// pwmval=pwmval-1;
// t=pwmval;
// delay_ms(5);
// if(pwmval==1)
// flag1=1;
// if(flag1==1)
// pwmval=pwmval-1;
// t=pwmval;
// delay_ms(5);
// if(pwmval==1)
// flag1=0;
// pwmval=pwmval+1;
// t=pwmval;
// delay_ms(5);
// if(pwmval==1000)
// flag1=0;
MAIN 函数
int main(void)
SysClock_Init();
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
// EXTI_Configuration();
// TIM2_Configuration();
// TIM4_PWM_Configuration(1000,0 ); //对时钟不进行分频,72000HZ
TIM3_Encoder_Configuration();
// TIM_SetCompare1(TIM3,pwmval);
USART1_Configuration(9600); // 配置串口1,波特率9600
while(1)
encoder_num=TIM_GetCounter(TIM3);
// keyscan();
// TIM_SetCompare1(TIM4,pwmval);//设置TIMx捕获比较1寄存器值
it.c
* @file Project/STM32F10x_StdPeriph_Template/stm32f10x_it.c
* @author MCD Application Team
* @version V3.4.0
* @date 10/15/2010
* @brief Main Interrupt Service Routines.
* This file provides template for all exceptions handler and
* peripherals interrupt service routine.
* @copy
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2010 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_it.h"
//#include"stdio.h"
//extern void delay_ms(u16 time);
//extern int pwmval,flag,t;
static int sum;
extern int encoder_num;
/** @addtogroup STM32F10x_StdPeriph_Template
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/* Cortex-M3 Processor Exceptions Handlers */
* Function Name : EXTI0_IRQHandler
* Description : This function handles USART1 global interrupt request.
* Input : None
* Output : None
* Return : None
//void EXTI0_IRQHandler()
// if(EXTI_GetITStatus(EXTI_Line0) != RESET)
// pwmval=0;
// EXTI_ClearITPendingBit(EXTI_Line0);
* Function Name : EXTI1_IRQHandler
* Input : None
* Output : None
* Return : None
//void EXTI1_IRQHandler()
// if(EXTI_GetITStatus(EXTI_Line1) != RESET)
// pwmval=t;
// EXTI_ClearITPendingBit(EXTI_Line1);
* Function Name : USART1_IRQHandler
* Input : None
* Output : None
* Return : None
void USART1_IRQHandler(void)
int i,k,index=0;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) // 如果是串口接收中断
// if((USART_ReceiveData(USART1))!=' ') //
// sum=sum*10+(USART_ReceiveData(USART1)-48);
if((USART_ReceiveData(USART1))==' ')
char str[10];
// encoder_num=100;
// TIM_SetCompare1(TIM3,sum);
//// sum=10000-sum;
// k=sum;
sum=encoder_num;
k=sum;
for(i=0;k>0;i++) /*index保存i的位数*/
k = k / 10;
index++;
for(i=0;i<index;i++)
str[index-i-1]=sum%10+48; /*记得加'0'*/
sum=sum/ 10;
USART_SendData(USART1, str[i]);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
sum=0;
//void USART1_IRQHandler(void)
// int i,k,index=0;
// if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) // 如果是串口接收中断
// if((USART_ReceiveData(USART1))==' ')
// char str[5];
// pwmval=sum;
//// TIM_SetCompare1(TIM3,sum);
//// sum=10000-sum;
// k=sum;
// for(i=0;k>0;i++) /*index保存i的位数*/
// k = k / 10;
// index++;
// for(i=0;i<index;i++)
// str[index-i-1]=sum%10+48; /*记得加'0'*/
// sum=sum/ 10;
// USART_SendData(USART1, str[i]);
// while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
// sum=0;
// static int j=0;
// static char str[5];
// char str_1[5];
// int i=1,k,n=0,index=0,m;
// if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)// 如果是串口接收中断
// USART_ClearITPendingBit(USART1,USART_IT_RXNE);//清除USARTx的中断待处理位
// USART_ClearFlag(USART1,USART_FLAG_TC); //清除标志位
// if(USART_ReceiveData(USART1)!=' ')
// str[j]=USART_ReceiveData(USART1); // 将接收到的字节发送出去
// j++;
// if(USART_ReceiveData(USART1)==' ')
// m=strlen(str);
// for(j=0;j<m-1;j++)
// i=i*10;
// for(j=0;j<m;j++)
// n=(str[j]-48)*i+n;
// i=i/10;
// for(j=0;j<m;j++)
// str[j]='\0';
// n=10000-n;
// k=n;
// while(n>0)/*index保存x的位数*/
// n = n / 10;
// index++;
// for(j=0;j<index;j++)
// str_1[index-j-1] = k % 10 +48;/*记得加'0'*/
// k = k / 10;
// USART_SendData(USART1,str_1[j]);
// j=0;
// char value;
// value=USART_ReceiveData(USART1);
// USART_SendData(USART1,value);
* Function Name : TIM2_IRQHandler
* Input : None
* Output : None
* Return : None
//void TIM2_IRQHandler(void)
// if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //检查指定的TIM中断发生与否:TIM1 中断源
// TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
// flag=1;
* Function Name : TIM3_IRQHandler
* Input : None
* Output : None
* Return : None
//void TIM3_IRQHandler(void)
// if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //检查指定的TIM中断发生与否:TIM1 中断源
// TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)//判断是否为更新中断
TIM_ClearITPendingBit(TIM3, TIM_IT_CC1|TIM_IT_Update);//清除中断和捕获标志位
* @brief This function handles NMI exception.
* @param None
* @retval None
void NMI_Handler(void)
* @brief This function handles Hard Fault exception.
* @param None
* @retval None
void HardFault_Handler(void)
/* Go to infinite loop when Hard Fault exception occurs */
while (1)
* @brief This function handles Memory Manage exception.
* @param None
* @retval None
void MemManage_Handler(void)
/* Go to infinite loop when Memory Manage exception occurs */
while (1)
* @brief This function handles Bus Fault exception.
* @param None
* @retval None
void BusFault_Handler(void)
/* Go to infinite loop when Bus Fault exception occurs */
while (1) {
* @brief This function handles Usage Fault exception.
* @param None
* @retval None
void UsageFault_Handler(void)
/* Go to infinite loop when Usage Fault exception occurs */
while (1)
* @brief This function handles SVCall exception.
* @param None
* @retval None
void SVC_Handler(void)
* @brief This function handles Debug Monitor exception.
* @param None
* @retval None
void DebugMon_Handler(void)
* @brief This function handles PendSVC exception.
* @param None
* @retval None
void PendSV_Handler(void)
* @brief This function handles SysTick Handler.
* @param None
* @retval None
void SysTick_Handler(void)
/* STM32F10x Peripherals Interrupt Handlers */
/* Add here the Interrupt Handler for the used peripheral(s) (PPP), for the */
/* available peripheral interrupt handler's name please refer to the startup */
/* file (startup_stm32f10x_xx.s). */
* @brief This function handles PPP interrupt request.
* @param None
* @retval None
/*void PPP_IRQHandler(void)
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
