注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
袁伟康2013的个人空间 https://home.eeworld.com.cn/space-uid-498889.html [收藏] [复制] [分享] [RSS]
日志
stm32半个月学习心得(二)
已有 570 次阅读2013-11-1 18:33 |个人分类:stm32|
这是我学习stm32半个月的心得,给其他人借鉴
(二)通用定时器 源码
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V2.0.1
* Date               : 06/13/2008
* Description        : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
u16 CCR1_Val = 500;
u16 CCR2_Val = 375;
u16 CCR3_Val = 250;
u16 CCR4_Val = 125;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
    TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
    TIM3CLK = 36 MHz, Prescaler = 0x0, TIM3 counter clock = 36 MHz
    TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
    TIM3 Frequency = 36 KHz.
    TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
    TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
    TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
    TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
  TIM_OC3Init(TIM3, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
  TIM_OC4Init(TIM3, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);
  while (1)
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/4 */
    RCC_PCLK1Config(RCC_HCLK_Div4);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configure the TIM3 Ouput Channels.
* Input          : None
* Output         : None
* Return         : None
  GPIO_InitTypeDef GPIO_InitStructure;
  /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
