注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
jiajie270的个人空间 https://home.eeworld.com.cn/space-uid-422029.html [收藏] [复制] [分享] [RSS]
日志
按键加减数码管显示
已有 1995 次阅读2017-5-16 18:34 |个人分类:FPGA| false
//自己写的一个通过按键,控制数码管显示数据0-99的程序
主要练习:按键状态判断,按键消抖,哪一个按键按下判断,数码管扫描,数码管显示
module test_key3(CLK,RSTn,key_in,SEG_DATA,SEG_SEL);
input CLK;
input RSTn;
input [1:0]key_in;
output [7:0]SEG_DATA;
output [1:0]SEG_SEL;
reg [1:0]key_in_r;
wire [1:0]key_in_or;
//按键消抖
always @(posedge CLK or negedge RSTn)
begin
         if(!RSTn)
                   key_in_r<=2'b11;
         else
                   key_in_r<=key_in;
end
assign key_in_or=key_in_r^key_in;  //用于判断是否有按键变化
parameter T20MS=20'd1000_000;                   //20MS用于按键消抖
reg [19:0]counter2;
begin
         if(!RSTn)
                   counter2<=20'd0;
         else if(counter2==T20MS || key_in_or)  //计时满20ms或者有按键变化时counter2清零
                                     counter2<=20'd0;
                            else
                                     counter2<=counter2+20'b1;
end
reg [1:0]key_s;
reg [1:0]key_s_n;
begin
         if(!RSTn)
                   key_s<=2'b11;
         else
                   key_s<=key_s_n;
end
begin
         if(!RSTn)
                   key_s_n<=2'b11;
         else if(counter2==T20MS)
                            key_s_n<=key_in;
                            else
                            key_s_n<=key_s_n;                   //开始时此处写成了key_s_n<=key_s造成错误
end
parameter T10MS=20'd500_000;                      //10MS用于数码管扫描
reg [19:0]counter;
begin
         if(!RSTn)
                   counter<=20'd0;
         else if(counter==T10MS)
                                     counter<=20'd0;
                            else
                                     counter<=counter+20'b1;
end
reg t;
always @(posedge CLK or negedge RSTn)                //t用于数码管扫描
begin
         if(!RSTn)
                   t<=1'b0;
                                     t<=~t;
end
reg [6:0]counter1;
begin
         if(!RSTn)
                   counter1<=7'd0;
         else if(counter1==7'd100)
                                     counter1<=7'd0;
                            else if(counter1==7'd127)
                                                        counter1<=7'd99;
                                               else case({key_s,key_s_n})               //{key_s,key_s_n}用于判断是哪一个按键发生了按下或者放开的操作
        4'b1110:counter1<=counter1+7'd1;
        4'b1101:counter1<=counter1-7'd1;
        default:counter1<=counter1;
        endcase
end
reg [3:0]ge;
reg [3:0]shi;
always @(posedge CLK or negedge RSTn)                //用于计算数据位
begin
         if(!RSTn)
                   begin
                            ge<=4'b0;
                            shi<=4'b0;
                   end
         else
                   begin
                            ge<=counter1%10;
                            shi<=counter1/10;
                   end
end
reg [7:0]ge_SEG_DATA;
begin
         if(!RSTn)
                   ge_SEG_DATA<=8'hc0;
         else case(ge)
                   4'd0:ge_SEG_DATA<=8'hc0;
                   4'd1:ge_SEG_DATA<=8'hf9;
                   4'd2:ge_SEG_DATA<=8'ha4;
                   4'd3:ge_SEG_DATA<=8'hb0;
                   4'd4:ge_SEG_DATA<=8'h99;
                   4'd5:ge_SEG_DATA<=8'h92;
                   4'd6:ge_SEG_DATA<=8'h82;
                   4'd7:ge_SEG_DATA<=8'hf8;
                   4'd8:ge_SEG_DATA<=8'h80;
                   4'd9:ge_SEG_DATA<=8'h90;
                   default:ge_SEG_DATA<=8'hff;
                            endcase
end
reg [7:0]shi_SEG_DATA;
begin
         if(!RSTn)
                   shi_SEG_DATA<=8'hc0;
         else case(shi)
                   4'd0:shi_SEG_DATA<=8'hc0;
                   4'd1:shi_SEG_DATA<=8'hf9;
                   4'd2:shi_SEG_DATA<=8'ha4;
                   4'd3:shi_SEG_DATA<=8'hb0;
                   4'd4:shi_SEG_DATA<=8'h99;
                   4'd5:shi_SEG_DATA<=8'h92;
                   4'd6:shi_SEG_DATA<=8'h82;
                   4'd7:shi_SEG_DATA<=8'hf8;
                   4'd8:shi_SEG_DATA<=8'h80;
                   4'd9:shi_SEG_DATA<=8'h90;
                   default:shi_SEG_DATA<=8'hff;
                     endcase
end
reg [1:0]rSEG_SEL;
reg [7:0]rSEG_DATA;
begin
         if(!RSTn)
         begin
                   rSEG_SEL<=2'b01;
                   rSEG_DATA<=8'hc0;
         end
         else case(t)
                            1'b0:begin
                                               rSEG_SEL<=2'b01;
                                               rSEG_DATA<=ge_SEG_DATA;
                                       end
                            1'b1:begin
                                               rSEG_SEL<=2'b10;
                                               rSEG_DATA<=shi_SEG_DATA;
                                       end
                            default:begin
                                                        rSEG_SEL<=2'b11;
                                                        rSEG_DATA<=8'hff;
                                                        end
                            endcase
end
assign SEG_DATA=rSEG_DATA;
assign SEG_SEL=rSEG_SEL;
endmodule
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
