注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
yedaochang的个人空间 https://home.eeworld.com.cn/space-uid-398460.html [收藏] [复制] [分享] [RSS]
日志
TI bq EVSW Version
已有 4281 次阅读2014-5-22 16:33 | EVSW, Version, bq20z80, 2013-12-10, COV
bq EVSW Version = 0.9.88
DeviceName = bq20z80 v1.10
Time = 2013-12-10 10:51:42
[Voltage(1st Level Safety)]
COV Threshold = 4300
COV Time = 2
COV Recovery = 104
COV Delta = 20
COV Temp. Hys = 100
POV Threshold = 8600
POV Time = 2
POV Recovery = 8400
CUV Threshold = 2700
CUV Time = 2
CUV Recovery = 2800
PUV Threshold = 6000
PUV Time = 2
PUV Recovery = 6200
[Current(1st Level Safety)]
OC (1st Tier) Chg = 1500
OC (1st Tier) Chg Time = 8
OC Chg Recovery = 200
OC (1st Tier) Dsg = 2500
OC (1st Tier) Dsg Time = 8
OC Dsg Recovery = 200
OC (2nd Tier) Chg = 2250
OC (2nd Tier) Chg Time = 2
OC (2nd Tier) Dsg = 3000
OC (2nd Tier) Dsg Time = 2
Current Recovery Time = 8
AFE OC Dsg = 12
AFE OC Dsg Time = 0F
AFE OC Dsg Recovery = 100
AFE SC Chg Cfg = 77
AFE SC Dsg Cfg = 77
AFE SC Recovery = 1
[Temperature(1st Level Safety)]
Over Temp Chg = 600
OT Chg Time = 2
OT Chg Recovery = 550
Over Temp Dsg = 610
OT Dsg Time = 2
OT Dsg Recovery = 600
[Host Comm(1st Level Safety)]
Host Watchdog Timeout = 0
[Voltage(2nd Level Safety)]
SOV Threshold = 8800
SOV Time = 5
Cell Imbalance Current = 5
Cell Imbalance Fail Voltage = 200
Cell Imbalance Time = 5
Battery Rest Time = 1800
PFIN Detect Time = 0
[Current(2nd Level Safety)]
SOC Chg = 4000
SOC Chg Time = 0
SOC Dsg = 500
SOC Dsg Time = 0
[Temperature(2nd Level Safety)]
SOT Chg = 650
SOT Chg Time = 0
SOT Dsg = 750
SOT Dsg Time = 0
Open Thermistor = -333
Open Time = 0
[FET Verification(2nd Level Safety)]
FET Fail Limit = 20
FET Fail Time = 5
[AFE Verification(2nd Level Safety)]
AFE Check Time = 0
AFE Fail Limit = 10
AFE Fail Recovery Time = 20
AFE Init Retry Limit = 6
AFE Init Limit = 20
[Fuse Verification(2nd Level Safety)]
Fuse Fail Limit = 2
Fuse Fail Time = 0
[Charge Inhibit Cfg(Charge Control)]
Chg Inhibit Temp Low = 0
Chg Inhibit Temp High = 600
Temp Hys = 10
[Pre-Charge Cfg(Charge Control)]
Pre-chg Current = 250
Pre-chg Temp = 90
Pre-chg Voltage = 3000
Recovery Voltage = 3100
[Fast Charge Cfg(Charge Control)]
Fast Charge Current = 1000
Charging Voltage = 8100
Delta Temp = 50
Suspend Low Temp = -50
Suspend High Temp = 600
[Pulse Charge Cfg(Charge Control)]
Turn ON Voltage = 3900
Turn OFF Voltage = 5000
Max ON Pulse Time = 240
Min OFF Pulse Time = 0
Max OFF Voltage = 5000
[Termination Cfg.(Charge Control)]
Maintenance Current = 0
Taper Current = 100
Termination Voltage = 200
Current Taper Window = 30
TCA Set % = -1
TCA Clear % = 25
FC Set % = -1
FC Clear % = 98
[Cell Balancing Cfg(Charge Control)]
Min Cell Deviation = 1750
[Charging Faults(Charge Control)]
Over Charging Voltage = 500
Over Charging Volt Time = 2
Over Charging Current = 500
Over Charging Curr Time = 2
Over Charging Curr Recov = 100
Depleted Voltage = 5000
Depleted Voltage Time = 2
Depleted Recovery = 6000
Over Charge Capacity = 300
Over Charge Recovery = 2
FC-MTO = 0
PC-MTO = 0
Charge Fault Cfg = 0C
[Data(SBS Configuration)]
Rem Cap Alarm = 300
Rem Energy Alarm = 4320
Rem Time Alarm = 10
Init Battery Mode = 0081
Design Voltage = 7200
Spec Info = 0031
Manuf Date = 05-Dec-2013
Ser. Num. = 0019
Cycle Count = 11
CC Threshold = 500
CC % = 37
CF MaxError Limit = 100
Design Capacity = 2900
Design Energy = 2088
Manuf Name = Nexergy
Device Name = bq20z80
Device Chemistry = LION
[Configuration(SBS Configuration)]
TDA Set % = -1
TDA Clear % = 8
FD Set % = -1
FD Clear % = 5
TDA Set Volt Threshold = 5000
TDA Set Volt Time = 5
TDA Clear Volt = 6500
FD Set Volt Threshold = 6400
FD Volt Time = 5
FD Clear Volt = 6800
[Manufacturer Data(System Data)]
Pack Lot Code = 0000
PCB Lot Code = 0000
Firmware Version = 0299
Hardware Revision = 5240
Cell Revision = 0000
[Manufacturer Info(System Data)]
Manuf. Info = 27100025
[Lifetime Data(System Data)]
Lifetime Max Temp = 345
Lifetime Min Temp = 154
Lifetime Max Cell Voltage = 4087
Lifetime Min Cell Voltage = 2983
Lifetime Max Pack Voltage = 8155
Lifetime Min Pack Voltage = 6003
Lifetime Max Chg Current = 1013
Lifetime Max Dsg Current = -1073
Lifetime Max Chg Power = 798
Lifetime Max Dsg Power = -828
Life Max AvgDsg Cur = -996
Life Max AvgDsg Pow = -753
Lifetime Avg Temp = 188
[Lifetime Temp Samples(System Data)]
LT Temp Samples = 1955
[Registers(Configuration)]
Operation Cfg A = 0121
Operation Cfg B = 2CD9
Operation Cfg C = 0000
Permanent Fail Cfg = 0000
Non-Removable Cfg = 0000
[LED Cfg(LED Support)]
LED Flash Rate = 512
LED Blink Rate = 1024
LED Delay = 100
LED Hold Time = 4
CHG Flash Alarm = 10
CHG Thresh 1 = 0
CHG Thresh 2 = 20
CHG Thresh 3 = 40
CHG Thresh 4 = 60
CHG Thresh 5 = 80
DSG Flash Alarm = 10
DSG Thresh 1 = 0
DSG Thresh 2 = 20
DSG Thresh 3 = 40
DSG Thresh 4 = 60
DSG Thresh 5 = 80
[Power(Power)]
Flash Update OK Voltage = 6000
Shutdown Voltage = 5000
Shutdown Time = 10
Charger Present = 3000
Sleep Current = 3
Bus Low Time = 10
Cal Inhibit Temp Low = 50
Cal Inhibit Temp High = 450
Sleep Voltage Time = 100
Sleep Current Time = 100
[IT Cfg(Gas Gauging)]
Load Select = 3
Load Mode = 1
Min % Passed Chg for Qm = 37
Qmax Filter = 96
Term Voltage = 6300
User Rate-mA = 0
User Rate-mW = 0
Reserve Cap-mAh = 0
Reserve Cap-mWh = 0
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 6
Chg Current Threshold = 10
Quit Current = 3
Dsg Relax Time = 10
Chg Relax Time = 10
[State(Gas Gauging)]
Qmax Cell 0 = 2850
Qmax Cell 1 = 2850
Qmax Cell 2 = 2900
Qmax Cell 3 = 2900
Qmax Pack = 2850
Update Status = 06
Cell 0 Chg dod at EoC = 1920
Cell 1 Chg dod at EoC = 1936
Cell 2 Chg dod at EoC = 0
Cell 3 Chg dod at EoC = 0
Avg I Last Run = -993
Avg P Last Run = -753
Delta Voltage = 4
[R_a0(Ra Table)]
Cell0 R_a flag = 0000
Cell0 R_a 0 = 169
Cell0 R_a 1 = 169
Cell0 R_a 2 = 193
Cell0 R_a 3 = 238
Cell0 R_a 4 = 177
Cell0 R_a 5 = 160
Cell0 R_a 6 = 195
Cell0 R_a 7 = 301
Cell0 R_a 8 = 248
Cell0 R_a 9 = 294
Cell0 R_a 10 = 352
Cell0 R_a 11 = 597
Cell0 R_a 12 = 1319
Cell0 R_a 13 = 3031
Cell0 R_a 14 = 5174
[R_a1(Ra Table)]
Cell1 R_a flag = 0000
Cell1 R_a 0 = 121
Cell1 R_a 1 = 121
Cell1 R_a 2 = 138
Cell1 R_a 3 = 174
Cell1 R_a 4 = 131
Cell1 R_a 5 = 110
Cell1 R_a 6 = 142
Cell1 R_a 7 = 222
Cell1 R_a 8 = 181
Cell1 R_a 9 = 218
Cell1 R_a 10 = 255
Cell1 R_a 11 = 462
Cell1 R_a 12 = 1108
Cell1 R_a 13 = 2669
Cell1 R_a 14 = 4556
[R_a2(Ra Table)]
Cell2 R_a flag = FF55
Cell2 R_a 0 = 217
Cell2 R_a 1 = 217
Cell2 R_a 2 = 247
Cell2 R_a 3 = 371
Cell2 R_a 4 = 258
Cell2 R_a 5 = 198
Cell2 R_a 6 = 249
Cell2 R_a 7 = 374
Cell2 R_a 8 = 286
Cell2 R_a 9 = 391
Cell2 R_a 10 = 603
Cell2 R_a 11 = 1061
Cell2 R_a 12 = 2201
Cell2 R_a 13 = 4664
Cell2 R_a 14 = 7956
[R_a3(Ra Table)]
Cell3 R_a flag = FF55
Cell3 R_a 0 = 217
Cell3 R_a 1 = 217
Cell3 R_a 2 = 247
Cell3 R_a 3 = 371
Cell3 R_a 4 = 258
Cell3 R_a 5 = 198
Cell3 R_a 6 = 249
Cell3 R_a 7 = 374
Cell3 R_a 8 = 286
Cell3 R_a 9 = 391
Cell3 R_a 10 = 603
Cell3 R_a 11 = 1061
Cell3 R_a 12 = 2201
Cell3 R_a 13 = 4664
Cell3 R_a 14 = 7956
[R_a0x(Ra Table)]
xCell0 R_a flag = 0055
xCell0 R_a 0 = 169
xCell0 R_a 1 = 169
xCell0 R_a 2 = 193
xCell0 R_a 3 = 238
xCell0 R_a 4 = 175
xCell0 R_a 5 = 158
xCell0 R_a 6 = 193
xCell0 R_a 7 = 298
xCell0 R_a 8 = 245
xCell0 R_a 9 = 291
xCell0 R_a 10 = 348
xCell0 R_a 11 = 590
xCell0 R_a 12 = 1304
xCell0 R_a 13 = 2997
xCell0 R_a 14 = 5116
[R_a1x(Ra Table)]
xCell1 R_a flag = 0055
xCell1 R_a 0 = 121
xCell1 R_a 1 = 121
xCell1 R_a 2 = 138
xCell1 R_a 3 = 174
xCell1 R_a 4 = 128
xCell1 R_a 5 = 107
xCell1 R_a 6 = 139
xCell1 R_a 7 = 217
xCell1 R_a 8 = 177
xCell1 R_a 9 = 213
xCell1 R_a 10 = 249
xCell1 R_a 11 = 451
xCell1 R_a 12 = 1083
xCell1 R_a 13 = 2608
xCell1 R_a 14 = 4452
[R_a2x(Ra Table)]
xCell2 R_a flag = FFFF
xCell2 R_a 0 = 217
xCell2 R_a 1 = 217
xCell2 R_a 2 = 247
xCell2 R_a 3 = 371
xCell2 R_a 4 = 258
xCell2 R_a 5 = 198
xCell2 R_a 6 = 249
xCell2 R_a 7 = 374
xCell2 R_a 8 = 286
xCell2 R_a 9 = 391
xCell2 R_a 10 = 603
xCell2 R_a 11 = 1061
xCell2 R_a 12 = 2201
xCell2 R_a 13 = 4664
xCell2 R_a 14 = 7956
[R_a3x(Ra Table)]
xCell3 R_a flag = FFFF
xCell3 R_a 0 = 217
xCell3 R_a 1 = 217
xCell3 R_a 2 = 247
xCell3 R_a 3 = 371
xCell3 R_a 4 = 258
xCell3 R_a 5 = 198
xCell3 R_a 6 = 249
xCell3 R_a 7 = 374
xCell3 R_a 8 = 286
xCell3 R_a 9 = 391
xCell3 R_a 10 = 603
xCell3 R_a 11 = 1061
xCell3 R_a 12 = 2201
xCell3 R_a 13 = 4664
xCell3 R_a 14 = 7956
[Device Status Data(PF Status)]
PF Flags 1 = 0000
Fuse Flag = 0000
PF Voltage = 0
PF C4 Voltage = 0
PF C3 Voltage = 0
PF C2 Voltage = 0
PF C1 Voltage = 0
PF Current = 0
PF Temperature = 0
PF Batt Stat = 0000
PF RC-mAh = 0
PF RC-10mWh = 0
PF Chg Status = 0000
PF Safety Status = 0000
PF Flags 2 = 0000
[AFE Regs(PF Status)]
AFE Status = 00
AFE Output = 00
AFE State = 00
AFE Function = 00
AFE Cell Select = 00
AFE OLV = 00
AFE OLT = 00
AFE SCC = 00
AFE SCD = 00
[Data(Calibration)]
CC Gain = 0.4222
CC Delta = 125934.3047
Ref Voltage = 2450.0
AFE Corr = 1288
AFE Pack Gain = 30625
CC Offset = -11909
Board Offset = 0
Int Temp Offset = -74
Ext1 Temp Offset = 0
Ext2 Temp Offset = 0
[Config(Calibration)]
CC Current = 0
Voltage Signal = 0
Temp Signal = 0.0
CC Offset Time = 250
ADC Offset Time = 32
CC Gain Time = 250
Voltage Time = 1984
Temperature Time = 32
Cal Mode Timeout = 38400
[Temp Model(Calibration)]
Ext Coef 1 = -28285
Ext Coef 2 = 20848
Ext Coef 3 = -7537
Ext Coef 4 = 4012
Ext Min AD = 0
Ext Max Temp = 4012
Int Coef 1 = 0
Int Coef 2 = 0
Int Coef 3 = -11136
Int Coef 4 = 5754
Int Min AD = 0
Int Max Temp = 5754
[Current(Calibration)]
Filter = 239
Deadband = 3
CC Deadband = 34
CC Max Deadband = 5
CC Deadband Sample = 256
CC Max Offset Sample = 64
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
