注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
lcofjp的个人空间 https://home.eeworld.com.cn/space-uid-367757.html [收藏] [复制] [分享] [RSS]
日志
2016-05-31
已有 1166 次阅读2016-5-31 15:26 |个人分类:linux/unix| applescript
Code:
  TABELLE    key codes    SYSTEM EVENTS IN APPLESCRIPT
  (Deutsche Apple USB-Tastatur, evtl. auch f. andere
   Tastaturen gültig, alle Angaben ohne Gewähr)
key code   1 = "s"              key code  33 = "ü"
key code   2 = "d"              key code  34 = "i"
key code   3 = "f"              key code  35 = "p"
key code   4 = "h"              key code  36 = [Return]    ↵
key code   5 = "g"              key code  37 = "l"
key code   6 = "y"              key code  38 = "j"
key code   7 = "x"              key code  39 = "ä"
key code   8 = "c"              key code  40 = "k"
key code   9 = "v"              key code  41 = "ö"
key code  10 = "^"              key code  42 = "#"
key code  11 = "b"              key code  43 = ","
key code  12 = "q"              key code  44 = "-"
key code  13 = "w"              key code  45 = "n"
key code  14 = "e"              key code  46 = "m"
key code  15 = "r"              key code  47 = "."
key code  16 = "z"              key code  48 = [Tab]       ⇥
key code  17 = "t"              key code  49 = [Space]
key code  18 = "1"              key code  50 = "<"
key code  19 = "2"              key code  51 = [Bkw-Del]   ⌫
key code  20 = "3"              key code  52 = [Return]    ↵
key code  21 = "4"              key code  53 = [Escape]   esc
key code  22 = "6"              key code  54 = [Command]   ⌘
key code  23 = "5"              key code  55 = [Command]   ⌘
key code  24 = "′"              key code  56 = [Shift]     ⇧
key code  25 = "9"              key code  57 = [ShiftLock] ⇪
key code  26 = "7"              key code  58 = [Alt]       ⎇
key code  27 = "ß"              key code  59 = [Ctrl]   ctrl
key code  28 = "8"              key code  60 = [Shift]     ⇧
key code  29 = "0"              key code  61 = [Alt]       ⎇
key code  30 = "+"              key code  62 = [Ctrl]   ctrl
key code  31 = "o"              key code  63
key code  32 = "u"              key code  64
key code  65 = NUM [,]          key code  97 = [F 6]
key code  66 = [ArrowRight]     key code  98 = [F 7]
key code  67 = NUM [*]          key code  99 = [F 3]
key code  68                    key code 100 = [F 8]
key code  69 = NUM [+]          key code 101 = [F 9]
key code  70 = [ArrowLeft]      key code 102
key code  71 = NUM [X]          key code 103 = [F11]
key code  72 = [ArrowDown]      key code 104
key code  73                    key code 105 = [F13]
key code  74                    key code 106 = [F16]
key code  75 = NUM [/]          key code 107 = [F14]
key code  76 = NUM [Enter]      key code 108
key code  77 = [ArrowUp]        key code 109 = [F10]
key code  78 = NUM [-]          key code 110
key code  79                    key code 111 = [F12]
key code  80                    key code 112
key code  81 = NUM [=]          key code 113 = [F15]
key code  82 = NUM [0]          key code 114 = [Help]
key code  83 = NUM [1]          key code 115 = [PgUp]
key code  84 = NUM [2]          key code 116 = [Home]
key code  85 = NUM [3]          key code 117 = [Fwd-Del]
key code  86 = NUM [4]          key code 118 = [F 4]
key code  87 = NUM [5]          key code 119 = [PgDwn]
key code  88 = NUM [6]          key code 120 = [F 2]
key code  89 = NUM [7]          key code 121 = [End]
key code  90                    key code 122 = [F 1]
key code  91 = NUM [8]          key code 123 = [ArrowLeft]
key code  92 = NUM [9]          key code 124 = [ArrowRight]
key code  93                    key code 125 = [ArrowDown]
key code  94                    key code 126 = [ArrowUp]
key code  95                    key code 127
key code  96 = [F 5]            key code 128 = "a"
ab 129 gehts wieder von vorn los (129 = "s", 130 = "d", usw.)
osascript -e 'tell application "System Events" to key code 122 using command down'
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
