注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
youyou_hu111的个人空间 https://home.eeworld.com.cn/space-uid-361734.html [收藏] [复制] [分享] [RSS]
日志
富士通mb9bf506串口通讯
已有 3740 次阅读2012-7-15 22:05
比较关注我们家庭物联网的网友都会有个疑问,很多人都没在做富士通,在做430。其实我们是有原因的,因为物联网注定了我们需要网络节点,而富士通板子只有一块,所以采用了TI的430作为子节点的控制芯片。
现奉上MB9BF506R的串口通讯代码:
   [NOTE] Connected chart
     PC
   | Baudrate : 9600 bps |
   | DataBit  : 8 bit      |
   | Parity   : None       | <-----> MFS Ch4@MB9BF506 Board
   | StopBit  : 1 bit      |
   | FlowCtl  : None       |
#include <intrinsics.h>
#include <stdio.h>
#include <stdlib.h>
#include <Fujitsu/iomb9bf506r.h>
#include <assert.h>
 * Function Name: NVIC_IntEnable
 * Parameters: IntNumber - Interrup number
 * Return: void
 * Description: Enable interrup at NVIC
void NVIC_IntEnable(unsigned char IntNumber)
  volatile unsigned long * pNVIC_SetEn = &SETENA0;
//  assert((NVIC_FCS <= IntNumber) && (NVIC_DMA_CH7 >= IntNumber));
  IntNumber -= NVIC_FCS;
  pNVIC_SetEn += IntNumber/32;
  *pNVIC_SetEn = (1UL<<(IntNumber%32));
 * Function Name: InitClock
 * Parameters: void
 * Return: void
 * Description: Initialize PLL to 80MHz,
 *              Base Clock  = 80MHz
 *              APB0 = APB1 = APB2 = 40MHz
void InitClock(void)
    /*set Main clock stabilization
    wait time to 2ms*/
    CSW_TMR_bit.MOWT = 9;
    /*Enable Main Oscilator*/
    SCM_CTL_bit.MOSCE = 1;
    /*Wait stabilization end*/
    while(!SCM_STR_bit.MORDY);
    /*Set PLL stabilization
    wait time to 512uS*/
    PSW_TMR_bit.POWT = 2;
    /*Set PLL to 80MHz*/
    PLL_CTL1 = 0; /*K = 1, M=1*/
    PLL_CTL2 = 19; /*N = 20*/
    /*Enable PLL*/
    SCM_CTL_bit.PLLE = 1;
    /*Set bus prescalers*/
    BSC_PSR_bit.BSR = 0;      /*Base clock Prescaler 1:1*/
    APBC0_PSR_bit.APBC0 = 2;  /*APB0 clock Prescaler 1:2*/
    APBC1_PSR_bit.APBC1 = 2;  /*APB1 clock Prescaler 1:2*/
    APBC2_PSR_bit.APBC2 = 2;  /*APB2 clock Prescaler 1:2*/
    /*Wait PLL stabilizatoin end*/
    while(!SCM_STR_bit.PLRDY);
    /*Select PLL for main clock*/
    SCM_CTL_bit.RCS = 2;
    /*Wait PLL to be connected*/
    while(2 != SCM_STR_bit.RCM);
void MFSI_RX2_IRQHandler(void)
    char rx_buff;
   if(((UART2_SSR&0x08)>>3) == 1)
       UART2_SSR = 0x80;
   else
       rx_buff=UART2_RDR;
       if(rx_buff == 0xaa)
           PDOR3 = 0x00;
       UART2_TDR = UART2_RDR;
void MFSI_TX2_IRQHandler(void)
  //  char tx_buff;
/*   if(((UART2_SSR&0x03)>>1) == 1)
       UART2_RDR = 0xaa;
  //     if(rx_buff == 0x00f8)
           PDOR3 = 0x00;
  //     else if(rx_buff == 0x00)
           PDOR3 = 0x0c00;
   UART2_SSR = 0x80;
int main(void)
    char rx_buff;
    /*Unlock sequence*/
    WDG_LCK = 0x1ACCE551;
    WDG_LCK = 0xE5331AAE;
    WDG_CTL = 0;
    InitClock();
 //   UART2_SSR = 0x80;
    PFR3 = 0x0000;
    DDR3 = 0xffff;
    PDOR3 = 0x0000;
    /* Set Uart Ch2 Port, SIN2_1, SOT2_1 */
    PFR2 |= 0x0030;
    EPFR07 = 0x000a0000;
 //   PCR2 = 0xffff;
 //   DDR2 = 0xfffd;
 //   UART2_SCR |= 0x80;
    /*Progarmmable clear,disable receive,transmit,bus idle and data reception interrupt,enable transmission*/
    UART2_SCR = 0x1b;
    /*MODE 0(正常模式)   SIN引脚作为外部中断引脚   1位停止位   小端LSB  使能串口输出*/
    UART2_SMR = 0x11;
    /*不使能硬件流控制  NRZ  偶校验*/
    UART2_ESCR = 0x00;
    UART2_BGR = 0x0823;
    NVIC_IntEnable(NVIC_MFSI_RX2);
    NVIC_IntEnable(NVIC_MFSI_TX2);
    while(1)
        if(((UART2_SSR&0x04)>>2) == 1)
            rx_buff=UART2_RDR;
            if(rx_buff == 0xaa)
              PDOR3 = 0x00;
              PDOR3 = 0x0c00;
  //      UART2_RDR = 0xaa;
接如下端口:
效果如下:
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
