注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
wateras1的个人空间 https://home.eeworld.com.cn/space-uid-361439.html [收藏] [复制] [分享] [RSS]
日志
Matlab的cftool几个名词含义
已有 915 次阅读2016-6-14 13:44 |个人分类:算法设计| matlab
误差项平方和 SSE: 1.972e-31
R方(吻合系数):R-square: 1
校正R方:Adjusted R-square: NaN
均方根误差 RMSE: NaN
给你一些资料:
SSE (趋向0最好)-- The sum of squares due to error. This statistic measures the deviation of the responses from the fitted values of the responses. A value closer to 0 indicates a better fit.
R-square(趋向1最好) -- The coefficient of multiple determination. This statistic measures how successful the fit is in explaining the variation of the data. A value closer to 1 indicates a better fit.
Adjusted R-square(趋向1最好) -- The degree of freedom adjusted R-square. A value closer to1 indicates a better fit. It is generally the best indicator of the fit quality when you add additional coefficients to your model.
RMSE(趋向0最好) -- The root mean squared error. A value closer to 0 indicates a better fit.
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
