视频讲解:
代码仓库:GitHub - LitchiCheng/mujoco-learning
上期介绍了Mujoco获取仿真中Panda机械臂末端的位置,实际上也可以获得其他关节的,今天介绍下data的另一个控制量,qpos,也就是关节位置,关键代码就一行
data.qpos[:7] = new_q
panda机械臂有七个关节的控制量,弧度单位,对应link0到link6,演示代码,控制某一个关节一直自增位置,但注意自增的量不能太大,不然控制台会输出如下,表示DOF 0不对劲,故需要归一到+-180°内
EEWORLDIMGTK1
完整代码如下
import mujoco
import numpy as np
import glfw
def scroll_callback(window, xoffset, yoffset):
global cam
# 调整相机的缩放比例
cam.distance *= 1 - 0.1 * yoffset
def limit_angle(angle):
while angle > np.pi:
angle -= 2 * np.pi
while angle < -np.pi:
angle += 2 * np.pi
return angle
def main():
global cam
# 加载模型
model = mujoco.MjModel.from_xml_path('/home/dar/MuJoCoBin/mujoco_menagerie/franka_emika_panda/scene.xml')
data = mujoco.MjData(model)
# 打印所有 body 的 ID 和名称
print("All bodies in the model:")
for i in range(model.nbody):
body_name = mujoco.mj_id2name(model, mujoco.mjtObj.mjOBJ_BODY, i)
print(f"ID: {i}, Name: {body_name}")
# 初始化 GLFW
if not glfw.init():
return
window = glfw.create_window(1200, 900, 'Panda Arm Control', None, None)
if not window:
glfw.terminate()
return
glfw.make_context_current(window)
# 设置鼠标滚轮回调函数
glfw.set_scroll_callback(window, scroll_callback)
# 初始化渲染器
cam = mujoco.MjvCamera()
opt = mujoco.MjvOption()
mujoco.mjv_defaultCamera(cam)
mujoco.mjv_defaultOption(opt)
pert = mujoco.MjvPerturb()
con = mujoco.MjrContext(model, mujoco.mjtFontScale.mjFONTSCALE_150.value)
scene = mujoco.MjvScene(model, maxgeom=10000)
# 找到末端执行器的 body id
end_effector_id = mujoco.mj_name2id(model, mujoco.mjtObj.mjOBJ_BODY, 'hand')
print(f"End effector ID: {end_effector_id}")
if end_effector_id == -1:
print("Warning: Could not find the end effector with the given name.")
glfw.terminate()
return
# 初始关节角度
initial_q = data.qpos[:7].copy()
while not glfw.window_should_close(window):
# 获取当前末端执行器位置
mujoco.mj_forward(model, data)
end_effector_pos = data.body(end_effector_id).xpos
initial_q[0] = initial_q[0] + 0.1
initial_q[0] = limit_angle(initial_q[0])
new_q = initial_q
# 设置关节目标位置
# 模拟一步
mujoco.mj_step(model, data)
# 更新渲染场景
viewport = mujoco.MjrRect(0, 0, 1200, 900)
mujoco.mjv_updateScene(model, data, opt, pert, cam, mujoco.mjtCatBit.mjCAT_ALL.value, scene)
mujoco.mjr_render(viewport, scene, con)
# 交换前后缓冲区
glfw.swap_buffers(window)
glfw.poll_events()
# 清理资源
glfw.terminate()
if __name__ == "__main__":
main()
