while (DEF_TRUE) { /* Task body, always written as an infinite loop. */
//BSP_LED_Toggle(0);
OSTimeDlyHMSM(0, 0, 0, 500);
GPIO_SetBits(GPIOE,GPIO_Pin_3);
GPIO_ResetBits(GPIOE,GPIO_Pin_3);
移植到STM32的是uC/OS官网的uC/OS-II V2.92,程序设置Led闪烁1s一次,但是实际调试的时候,Led闪烁的时间是2s一次。给出源代码,希望大家看看是什么问题?
cpu时钟获取:
CPU_INT32U BSP_CPU_ClkFreq (void)
RCC_ClocksTypeDef rcc_clocks;
RCC_GetClocksFreq(&rcc_clocks);
return ((CPU_INT32U)rcc_clocks.HCLK_Frequency);
设置SysTick时钟滴答重载值:
hclk_freq = BSP_CPU_ClkFreq(); /* Determine SysTick reference freq. */
cnts = hclk_freq / (CPU_INT32U)OS_TICKS_PER_SEC; /* Determine nbr SysTick increments in OS_TICKS_PER_SEC. */
OS_CPU_SysTickInit(cnts);
初始化SsyTick函数及开中断:
void OS_CPU_SysTickInit (INT32U cnts)
OS_CPU_CM3_NVIC_ST_RELOAD = cnts - 1u;
/* Set prio of SysTick handler to min prio. */
OS_CPU_CM3_NVIC_PRIO_ST = OS_CPU_CM3_NVIC_PRIO_MIN;
/* Enable timer. */
OS_CPU_CM3_NVIC_ST_CTRL |= OS_CPU_CM3_NVIC_ST_CTRL_CLK_SRC | OS_CPU_CM3_NVIC_ST_CTRL_ENABLE;
/* Enable timer interrupt. */
OS_CPU_CM3_NVIC_ST_CTRL |= OS_CPU_CM3_NVIC_ST_CTRL_INTEN;
我移植uC/OS-II V2.86的版本,没有什么问题,只是V2.92是针对F107评估板的,但是它和F103在时钟模块应该没啥区别啊,初始化RCC后均为72MHz,求学习交流!
