注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
yuanlily0106的个人空间 https://home.eeworld.com.cn/space-uid-341060.html [收藏] [复制] [分享] [RSS]
日志
STM32 1602液晶程序无显示!求高手!
已有 1771 次阅读2011-7-27 17:26
程序如下,急需高手指点!为什么程序下载到1602上无任何显示?
//LCD
#define   LOW_RS()    GPIOD->BRR =GPIO_Pin_6
#define   LOW_RW()    GPIOD->BRR =GPIO_Pin_5
#define   LOW_E()     GPIOD->BRR =GPIO_Pin_4 //端口位清除寄存器
#define   HI_RS()     GPIOD->BSRR=GPIO_Pin_6 //PE.0--(LCD)RS //端口位设置/清除寄存器
#define   HI_RW()     GPIOD->BSRR=GPIO_Pin_5 //PE.1--(LCD)RW
#define   HI_E()      GPIOD->BSRR=GPIO_Pin_4 //PE.2--(LCD)E
#define   DATAOUT     GPIOG->ODR   //端口输出数据寄存器
                           //端口输入数据寄存器
unsigned char LINE;
unsigned char ROW;
int LCD_DATA[12]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x2E,0x56};//要显示的ASC码,0x30为0的ASC码
int i=0;
//判断液晶屏忙
void LCD_WAIT()
 /* GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOD, &GPIO_InitStructure); //PD口输入*/
  GPIO_InitTypeDef GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  GPIO_Init(GPIOG, &GPIO_InitStructure); //PG口输入
 LOW_RS();  //命令
 HI_RW();   //读取
 do{
     HI_E();
     Delay(1);
  LOW_E();
     Delay(1);
 }while(GPIOG->IDR & 0x80);
  LOW_E();
  /*GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure); //PD口OD输出*/
  GPIO_Init(GPIOG, &GPIO_InitStructure); //PG口OD输出
void LCD_ENABLE(unsigned char a)
 LCD_WAIT();
 LOW_RS();
 LOW_RW();
 LOW_E();
 DATAOUT=a;
 HI_E();
 Delay(1);
 LOW_E();
 Delay(1);
void LCD_init()
 LCD_ENABLE(0x01);   //清屏
 LCD_ENABLE(0x38);   //2行8位数据(显示模式)
 LCD_ENABLE(0x0F);  //显示功能开,显示光标
 LCD_ENABLE(0x06);  //写入新数据后光标右移
 LCD_ENABLE(0x0C); //显示开
 LCD_ENABLE(0x80);
 LCD_ENABLE(0x18); //屏幕整体左移一格,用于滚动显示
 //LCD_ENABLE(0xC0);
void LCD_DISPLAY_INIT()
 LINE=1;
 ROW=1;
 if(LINE==1)
  LCD_ENABLE(0x80);//第一行,若为第二行,则为:LCD_ENABLE(0xc0);
 else
  LCD_ENABLE(0xC0);
void LCD_DISPLAY()
      while(1)
          LCD_WAIT();
          HI_RS();
          LOW_RW();
          DATAOUT=0x30;//ASC码输出到端口
          HI_E();
          Delay(1);
          LOW_E();
          Delay(1);
  LCD_ENABLE(0x0C);//关闭光标,显示
  LCD_ENABLE(0x01);
        Delay(1);
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
