注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
mcy_cool的个人空间 https://home.eeworld.com.cn/space-uid-320632.html [收藏] [复制] [分享] [RSS]
日志
WebClient V2.0
已有 1119 次阅读2013-3-4 09:09 |
// server.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <winsock2.h>
#include <windows.h>    // use Sleep function
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
// Need to link with Ws2_32.lib
#pragma comment(lib, "Ws2_32.lib")
#define DEFAULT_BUFLEN 2048
#define DEFAULT_PORT 27013
char RecvBuf[DEFAULT_BUFLEN];
char SendBuf[DEFAULT_BUFLEN];
char * TokenPtr = NULL;
struct sockaddr_in ServerCfg;
SOCKET ListenSocket = INVALID_SOCKET;
SOCKET ClientSocket = INVALID_SOCKET;
int cnt = 0;
char RespondInfo[] =
        "HTTP/1.1 200 OK\r\n"
        "Content-Type: text/html\r\n"
        "Connnection: close\r\n"
        "\r\n"
        "<!DOCTYPE HTML>\r\n"
"<p>"
        "<img src=\"http://www.coocox.org/images/CooCox.gif\" />"
        "</p>"
        "<html>\r\n"
        "<body>\r\n"
        "<form name=\"input\" method=\"get\">\r\n"
        "ON: \r\n"
        "<input type=\"radio\" name=\"LED\" value=\"ON\" checked=\"checked\">\r\n"
        "<br />\r\n"
        "OFF: \r\n"
        "<input type=\"radio\" name=\"LED\" value=\"OFF\">\r\n"
        "<br />\r\n"
        "<input type =\"submit\" value =\"Submit\">\r\n"
        "</form>\r\n"
        //"<h1 align=\"center\"><pre>"
        //"================= WIFI Shield Dirver===============<br />"
        //"Name: TCP Socket Http Webserver Example<br />"
        //"PORT : 27013<br />"
        //"===================<a href=\"http://www.coocox.org\">"
        //"CooCox Team</a>=====================<br />"
        //"</h1></pre>"
        "</body>\r\n"
        "</html>\r\n"
        "\r\n"
char RespondLED_ON[] =
        "\r\n"
"<p>"
        "</p>"
        "<html>\r\n"
        "<body>\r\n"
        "<p>LED Status</p>"
        "ON: \r\n"
        "<br />\r\n"
        "OFF: \r\n"
        "<br />\r\n"
        "</form>\r\n"
        "LED is ON"
        "</h1></pre>"
        "</body>\r\n"
        "</html>\r\n"
        "\r\n"
char RespondLED_OFF[] =
        "\r\n"
"<p>"
        "</p>"
        "<html>\r\n"
        "<body>\r\n"
        "<p>LED Status</p>"
        "ON: \r\n"
        "<input type=\"radio\" name=\"LED\" value=\"ON\">\r\n"
        "<br />\r\n"
        "OFF: \r\n"
        "<input type=\"radio\" name=\"LED\" value=\"OFF\" checked=\"checked\">\r\n"
        "<br />\r\n"
        "</form>\r\n"
        "LED is OFF"
        "</h1></pre>"
        "</body>\r\n"
        "</html>\r\n"
        "\r\n"
char Respond_ICO[] =
        "\r\n"
int main(void)
    WSADATA wsaData;
    int iResult = 0;
    int iSendResult = 0;
    //printf(WelcomeInfo);
    // Initialize Winsock
    iResult = WSAStartup(MAKEWORD(2,2), &wsaData);
    if (iResult != 0)
        printf("WSAStartup failed with error: %d\n", iResult);
        return 1;
    printf("Initial WinSock OK\r\n");
    // Create a SOCKET
    ListenSocket = socket(AF_INET, SOCK_STREAM, 0);
    if (ListenSocket == INVALID_SOCKET)
        printf("socket failed with error: %d\n", WSAGetLastError());
        WSACleanup();
        return 1;
    printf("Create Socket OK\r\n");
    // Setup the TCP listening socket
    ServerCfg.sin_family = AF_INET;
    ServerCfg.sin_port = htons(DEFAULT_PORT);
    ServerCfg.sin_addr.s_addr = htonl(INADDR_ANY);
    iResult = bind(ListenSocket,(struct sockaddr *)&ServerCfg,
            sizeof(struct sockaddr));
    if(iResult == SOCKET_ERROR)
        printf("bind failed with error: %d\n", WSAGetLastError());
        closesocket(ListenSocket);
        WSACleanup();
        return 1;
    printf("Bind to PORT OK\r\n");
    // Begin listen PORT
    iResult = listen(ListenSocket, 5);
    if (iResult == SOCKET_ERROR)
        printf("listen failed with error: %d\n", WSAGetLastError());
        WSACleanup();
        return 1;
    printf("Start Listen PORT\r\n");
    printf("Waitting Client ...\r\n");
    while(1)
        // Accept a client socket
        ClientSocket = accept(ListenSocket, NULL, NULL);
        if (ClientSocket == INVALID_SOCKET)
            printf("accept failed with error: %d\n", WSAGetLastError());
            WSACleanup();
            return 1;
        printf("\r\n=============================================\r\n");
        printf("Client Connect Now : %d\r\n", cnt++);
        // No longer need server socket
        //closesocket(ListenSocket);
        // Get Request
        // Receive Full response message
        printf("Receive Web bowser request\r\n\r\n");
        memset(RecvBuf, '\0', DEFAULT_BUFLEN);
        iResult = recv(ClientSocket, RecvBuf, DEFAULT_BUFLEN, 0);
        if (iResult < 0)
            printf("receive failed with error: %d\r\n", WSAGetLastError());
        else if(iResult > 0)
            puts(RecvBuf);
        else
            printf("Connect Closed!\r\n");
        TokenPtr = strstr(RecvBuf, "LED");
        if(TokenPtr == NULL)
TokenPtr = strstr(RecvBuf, "favicon.ico");
                // Send html to client
                iResult = send(ClientSocket, RespondInfo, strlen(RespondInfo), 0);
                    printf("send failed with error: %d\r\n", WSAGetLastError());
                printf("Send Get Respond OK\r\n");
            else
                iResult = send(ClientSocket, Respond_ICO, strlen(Respond_ICO), 0);
                printf("Send ICO Respond OK\r\n");
        else if(*(TokenPtr + 5) == 'F') //OFF
            iResult = send(ClientSocket, RespondLED_OFF, strlen( RespondLED_OFF), 0);
            printf("Send LED_OFF OK\r\n");
        else
            iResult = send(ClientSocket, RespondLED_ON, strlen( RespondLED_ON), 0);
            printf("Send LED_ON OK\r\n");
        //Wait 1S to allow boswer to receive information
        Sleep(1000);
        // shutdown the connection since no more data will be sent
        closesocket(ClientSocket);
        //WSACleanup();
        //printf("WebServer closed! Press Enter to exit\r\n");
        //getchar();
        //getchar();
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
