注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
houyisheri的个人空间 https://home.eeworld.com.cn/space-uid-309076.html [收藏] [复制] [分享] [RSS]
日志
利用iiC对芯片寄存器配置,仿真有问题,望高手指点
已有 600 次阅读2011-3-14 18:06
module iic(rst,clk,outdata,scl,sda,rst_out);
input rst;
input clk;
output outdata;
output scl;
inout sda;
output rst_out;   //the rst bit of the 371
//////////////////////////////////////////////////e
reg rst_out_r;
reg[7:0] j;
reg sense_r;
reg[7:0] reg_add_tmp;
reg[7:0] indata;
reg read_or_write;
parameter cap_config=8'b0000_0000;
parameter int_config1= 8'b1100_0100;
parameter int_config2=8'b0000_1001;
parameter ctrl_config= 8'b0000_0001;
assign rst_out = rst_out_r;
wire ack_out;
reg[9:0] cnt_10us;
reg[7:0] add1;
reg[7:0] add2;
always @ (posedge clk or negedge rst)
begin
 if(!rst) cnt_10us <= 5'd0;
 else cnt_10us <= cnt_10us+1'b1;
end
always@( ack_out or  rst)
begin
 if(!rst)
 begin
  rst_out_r<=1'b0;
  read_or_write<=1'b0;
  add1<=8'd4;
  add2<=8'd46;
  indata<=cap_config;
  sense_r<=1'b0;
  j<=8'd2;
  reg_add_tmp<=8'b0000_0110;//?
 end
 else if(cnt_10us==10'd500) rst_out_r<=1'b1;
 else if((j<=8'd5)&&(j>=8'd2))
  begin
   read_or_write<=0;
   reg_add_tmp<=add1+j;
   indata<=cap_config;
  end
 else if((j<=8'd13)&&(j>=8'd6))
  begin
   read_or_write<=0;
   if((j%8'd2)==0)
    indata<=int_config1;
    else indata<=int_config2;
  end
 else if(j==8'd14)
  begin
   read_or_write<=0;
   reg_add_tmp<=8'd1;
   indata<=ctrl_config;
  end
 else if(j==8'd15)
  begin
   read_or_write<=0;
   reg_add_tmp<=8'd0;
  end
 else if((j>=8'd16)&&(j<=8'd23))
  begin
   read_or_write<=1;
   reg_add_tmp<=add2+j;
  end
 else j<=8'd16;
 j<=j+8'd1;
 sense_r<=~sense_r;
end
reg[4:0] k;
reg outdata_r;
begin
 if(!rst)outdata_r<=0;
 else
  for(k=0;k<=7;k=k+1)
   begin
    outdata_r<=read_data[k];
   if(k==8) k<=0;
   end
end
assign outdata = outdata_r;
wire[8:0] read_data;
iic_com  iic_com(     .read_or_write(read_or_write),
       .reg_add(reg_add_tmp),
       .write_data(indata),
       .clk(clk),
       .rst(rst),
       .scl(scl),
       .sda(sda),
       .ack_out(ack_out),
       .outdata(read_data)
endmodule
本文含有来自论坛的附件或图片:[未命名.jpg],点击查看原帖附件。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
