注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
7leaves的个人空间 https://home.eeworld.com.cn/space-uid-301135.html [收藏] [复制] [分享] [RSS]
日志
【BB板使用心得之1】win7通过USB连接为BB板共享网络
已有 710 次阅读2013-12-16 15:12
资料来源:http://lanceme.blogspot.com/2013 ... et-sharing-for.html
这个网址不翻墙是访问不了的,所以我把原文发布到下面,整个文章应该很好理解,图文并茂,所以就没做翻译,大家应该看得懂,如果有不明的地方,请留言说明,我会解答
I wish I better understood WHY this was necessary.
At one point my BBB \"just worked\".  When it was plugged into my desktop computer via USB (Windows 7 machine) the BBB had internet connectivity just fine.  After working to solve other issues it stopped.  In any case, it works again with the following steps:
On the Windows 7 computer:
  •     Control Panel -> Network and Internet -> Network Connections
  •     Right-click your internet connection, Properties, Sharing Tab
  •     Click \"Allow other network users to connect thru this computer\'s Internet connection\"
  •     Select the BeagleBone Black\'s network connection under \"Home networking connection:\"
  •     Click OK.
    Here\'s the trick:  when I did this, Windows assigned a static IP to the BBB connection.  Why?  No idea.
    You have to go back to that connection and reset it to DHCP.
  •     Right-click the BeagleBone Black\'s connection, Properties
  •     Click Internet Protocol Version 4 (TCP/IPv4), Click Properties
  •     Click \"Optain an IP address automatically\"
  •     Click \"Obtain DNS server address automatically\"
  •     Click OK.  Click CLOSE.
On the BBB:
This makes the BBB route internet traffic thru the host (Windows 7 in this case) and DNS thru Google\'s DNS Servers (8.8.8.8).
    route add default gw 192.168.7.1
    echo \"nameserver 8.8.8.8\" >> /etc/resolv.conf
Try It:
    ping www.google.com
Make it Persistant:
To make this \"stick\" after a reboot of the BBB, you need to add these commands to the ethernet startup script on the BBB (/usr/bin/g-ether-load.sh).
NOTE:   You CANNOT simply add these commands to the bottom of that script file.  They must go  before the udhcpd starts.  It does not return control to the script so adding them at the bottom of the file does nothing for you.  My script file now looks like this:
    /sbin/ifconfig usb0 192.168.7.2 netmask 255.255.255.252
    /sbin/route add default gw 192.168.7.1
    echo \'nameserver 8.8.8.8\' >> /etc/resolv.conf
    /usr/sbin/udhcpd -f -S /etc/udhcpd.conf
IT WORKS!
A big thanks to robert@rplural.net who got me moving in the right direction.  Read his description of the parallel steps for a Linux host!
(javascript:;)
本文含有来自论坛的附件或图片点击查看原帖附件。
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
