注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
luooove的个人空间 https://home.eeworld.com.cn/space-uid-278928.html [收藏] [复制] [分享] [RSS]
日志
使用两块launchpad SPI传数据
已有 716 次阅读2014-10-18 21:10
用两块launchpad传SPI数据,一端发送一端接收,接收一端再用串口传给电脑显示。这是项目中一小段调试的程序。
发送程序
  1. #include
unsigned char MST_Data, SLV_Data;
  • int main(void)
      volatile unsigned int i;
  •   WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
      P1OUT = 0x00;                             // P1 setup for LED & reset output
      P1DIR |= BIT0 + BIT5;                     //
      P1SEL = BIT1 + BIT2 + BIT4;
      P1SEL2 = BIT1 + BIT2 + BIT4;
      UCA0CTL0 |= UCCKPL + UCMSB + UCMST + UCSYNC;  // 3-pin, 8-bit SPI master
      UCA0CTL1 |= UCSSEL_2;                     // SMCLK
      UCA0BR0 |= 0x02;                          // /2
      UCA0BR1 = 0;                              //
      UCA0MCTL = 0;                             // No modulation
      UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
      IE2 |= UCA0RXIE;                          // Enable USCI0 RX interrupt
      P1OUT &= ~BIT5;                           // Now with SPI signals initialized,
      P1OUT |= BIT5;                            // reset slave
  •   __delay_cycles(75);                 // Wait for slave to initialize
  •   MST_Data = 0x01;                          // Initialize data values
      while(1)
  •                   UCA0TXBUF = MST_Data;                     // Transmit first character
                      MST_Data++;
                      __delay_cycles(1000);
  •   //__bis_SR_register(LPM0_bits + GIE);       // CPU off, enable interrupts
    复制代码
    接收程序
    #include <msp430.h>
    int main(void)
      while (!(P1IN & BIT5));                   // If clock sig from mstr stays low,
                                                // it is not yet in SPI mode
    // P1DIR |= BIT6;
    // P1OUT |= BIT6;
        BCSCTL1 = CALBC1_16MHZ;                    // Set DCO
            DCOCTL = CALDCO_16MHZ;
            P1SEL = BIT1 + BIT2 + BIT5 + BIT6 + BIT7;                     // P1.1 = RXD, P1.2=TXD
            P1SEL2 = BIT1 + BIT2 + BIT5 + BIT6 + BIT7;
            UCA0BR0 = 0x82;                              // 16MHz 9600 UCA0BRX=1666=0x0682
            UCA0BR1 = 0x06;                              // 16MHz 9600
            UCA0MCTL = UCBRS2 + UCBRS1;               // Modulation UCBRSx = 6
            IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
      UCB0CTL1 = UCSWRST;                       // **Put state machine in reset**
      UCB0CTL0 |= UCCKPL + UCMSB + UCSYNC;      // 3-pin, 8-bit SPI master
      UCB0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
      IE2 |= UCB0RXIE;                          // Enable USCI0 RX interrupt
      __bis_SR_register(LPM4_bits + GIE);       // Enter LPM4, enable interrupts
    #pragma vector=USCIAB0RX_VECTOR
    __interrupt void USCI0RX_ISR(void)
      while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
      UCA0TXBUF = UCB0RXBUF;                    // TX -> RXed character
    测试通过可以。
    本文来自论坛,点击查看完整帖子内容。
    评论 (0 个评论)
    facelist doodle 涂鸦板
    您需要登录后才可以评论 登录 | 注册
    热门文章
    头条资讯
    新增数据手册
    热搜器件
    推荐下载
    推荐关注
