注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
a26409310的个人空间 https://home.eeworld.com.cn/space-uid-263238.html [收藏] [复制] [分享] [RSS]
日志
vb计算crc form8 十六进制 浮点 转换
已有 593 次阅读2010-4-12 18:27
'form1--form8,8个窗体,一个模块
’form8
Option Explicit
Private Type A_Single
aa As Single
End Type
Private Type A_Byte
bb(0 To
3)
As Byte
End Type
Dim
Da
As A_Single
Dim
By
As A_Byte
Private Function Str2Float(str As String) As
Double
Dim
k
As Integer
Dim
i
As Integer
Dim
j
As Integer
Dim
s
As Integer
Dim
SS
As Integer
Dim
As Integer
Dim
As Long
Dim
d
As Double
Dim
n
As Integer
Dim
h
As Integer
Dim
l
As Integer
Dim
s2()
As String,
st
As String
s2 = Split(str, " ")
If UBound(s2) <> 3 Then
MsgBox "数据格式错误,无法转换!"
Str2Float = 0
Exit Function
End If
For i = 0 To UBound(s2)
If Len(s2(i)) = 1 Then s2(i) = "0" & s2(i)
st = st & s2(i)
Next i
Dim
buff(7)
As Byte
For i = 0 To 7
buff(i) = Asc(Mid(st, i + 1, 1))
Next i
Dim
a(15)
As Byte
For i = 0 To 15
a(i) = i
Next i
Dim
b(7)
As Byte
For j = 0 To 7
If buff(j) >= 48 And buff(j) <= 57
Then
k = buff(j) - 48
b(j) = a(k)
ElseIf buff(j) >= 65 And buff(j) <=
70 Then
k = buff(j) - 65
b(j) = a(k + 10)
Else
Exit Function
End If
Next j
Dim
c(3)
As Long
For n = 0 To 6 Step 2
c(n / 2) = ((b(n) And &H7F) * (2 ^ 4)) Or (b(n + 1)
And &H7F)
Next n
s = c(0) \ 2 ^ 7
If s = 1 Then
SS = -1
Else
SS = 1
End If
E = ((c(0) And &H7F) * 2) Or ((c(1) And
&H80) \ 2 ^ 7)
M = ((c(1) And &HFFFFFF) * 2 ^ 16 And
&H7FFFFF) Or ((c(2) And &HFFFFFF) *
2 ^ 8) Or ((c(3) And &HFFFFFF))
d = SS * 2 ^ (E - 127) * (M / (2 ^ 23) + 1)
Str2Float = d
End Function
'Private Sub Command1_Click()
'Debug.Print Str2Float("A
D7
A3 3C")
'Text1.Text = Str2Float("A
D7
A3 3C")
'End Sub
If Text1.Text = "" Or Text2.Text = "" Or
Text3.Text = "" Or Text4.Text = "" Then
Exit Sub
End If
Text5.Text = ""
By.bb(0) = "&h"
& Text1.Text
By.bb(1) = "&h"
& Text2.Text
By.bb(2) = "&h"
& Text3.Text
By.bb(3) = "&h"
& Text4.Text
LSet Da = By
Text5.Text = Da.aa
End Sub
Private Sub Command2_Click()
Dim Arry_Out(0 To
3)
As Byte
If Not IsNumeric(Text5.Text) Then Exit Sub
Text1.Text = ""
Text2.Text = ""
Text3.Text = ""
Text4.Text = ""
Da.aa = Text5.Text
LSet By = Da
Arry_Out(0) = By.bb(0)
Arry_Out(1) = By.bb(1)
Arry_Out(2) = By.bb(2)
Arry_Out(3) = By.bb(3)
Text1.Text = Hex(Arry_Out(0))
Text2.Text = Hex(Arry_Out(1))
Text3.Text = Hex(Arry_Out(2))
Text4.Text = Hex(Arry_Out(3))
End Sub
Private Sub Command3_Click()
Unload Me
Form1.Show
End Sub
Private Sub Command4_Click()
End
End Sub
Private Sub Form_Load()
Text1.Text = ""
Text2.Text = ""
Text3.Text = ""
Text4.Text = ""
Text5.Text = ""
End Sub
分享
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
