'form1--form8,8个窗体,一个模块
’form5
Private Sub Command1_Click()
Dim CRC() As Byte
Dim s1 As String
Dim lens1 As Integer
Dim d() As Byte '待传输数据
Dim sd() As String '显示的字符
Text2.Text = ""
s1 = Replace(Text1.Text, " ", "")
lens1 = Len(s1)
If lens1 Mod 2 <> 0 Or s1 = ""
Then
MsgBox
"数据长度有误!", 64, "信息提示!! "
Text1.SetFocus
Exit
Sub
End If
ReDim sd(lens1)
For i = 0 To lens1 - 1
sd(i) =
Asc(Mid(s1, i + 1, 1))
If (sd(i)
> 47 And sd(i) < 58) Or (sd(i)
> 64 And sd(i) < 71) Or (sd(i)
> 96 And sd(i) < 103) Then
Else
MsgBox "数据输入有误!", 64, "信息提示!! "
Text1.SetFocus
Exit Sub
End If
Next i
ReDim d(lens1 \ 2 + 1) As Byte
For i = 0 To (lens1 \ 2) - 1 ' Step 2
d(i) =
"&H" & Mid(s1, i * 2 + 1, 2)
Next i
CRC = modbusCRC16(d) '调用CRC16计算函数
d(lens1 \ 2) =
CRC(1)
'CRC(0)为高位
d((lens1 \ 2) + 1) = CRC(0) 'CRC(1)为低位
ReDim sd(lens1 \ 2 + 1) As String
For i = 0 To (lens1 \ 2) + 1
If Val(d(i))
< 16 Then
sd(i) = "0" & Hex(d(i))
Else
sd(i) = Hex(d(i))
End If
If
Text2.Text = "" Then
Text2.Text = sd(i)
Else
Text2.Text = Text2.Text & " " &
sd(i)
End If
Next i
Label5.Caption = " " & lens1 \ 2
Label7.Caption = " " & lens1 \ 2 + 2
End Sub
Private Sub Command2_Click()
Text1.Text = ""
Text1.SetFocus
End Sub
Private Sub Command3_Click()
Label5.Caption = " " & 0
Label7.Caption = " " & 0
End Sub
Private Sub Command4_Click()
Dim CRC() As Byte
Dim s1 As String
Text4.Text = ""
s1 = Replace(Text3.Text, " ", "") '去掉所有空格
lens1 = Len(s1)
Then
MsgBox
Text3.SetFocus
Exit
Sub
End If
ReDim sd(lens1)
sd(i) =
Asc(Mid(s1, i + 1, 1)) '判断是否为十六进制字符
If (sd(i)
Else
Text3.SetFocus
Exit Sub
End If
Next i
ReDim d(lens1 \ 2) As Byte
d(lens1 \ 2) = 0
d(i) =
'd(lens1 \
2) = Val(d(lens1 \ 2)) + Val(d(i)) And &HFF
Next i
d(lens1 \ 2) = sum(d)
ReDim sd(lens1 \ 2) As String
For i = 0 To lens1 \ 2
If Val(d(i))
< 16 Then
Else
sd(i) = Hex(d(i))
End If
If
Text4.Text = "" Then
Text4.Text = sd(i)
Else
Text4.Text = Text4.Text & " " &
sd(i)
End If
Next i
Label11.Caption = " " & lens1 \ 2
Label13.Caption = " " & lens1 \ 2 + 1
End Sub
Private Sub Command5_Click()
Text3.Text = ""
Text3.SetFocus
End Sub
Private Sub Command6_Click()
Label11.Caption = " " & 0
Label13.Caption = " " & 0
End Sub
Private Sub Command7_Click()
Unload Me
Form1.Show
End Sub
Private Sub Command8_Click()
End
End Sub
Private Sub Form_Load()
Text1.Text = ""
Text2.Text = ""
Text3.Text = ""
Text4.Text = ""
End Sub
分享
顶
