注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
懒猫爱飞的个人空间 https://home.eeworld.com.cn/space-uid-238351.html [收藏] [复制] [分享] [RSS]
日志
CC2640学习-PWM驱动
已有 4022 次阅读2016-10-13 10:09 |个人分类:工作小记| CC2640, pwm
自己整理的CC2640的PWM驱动,目前只写了两通道,其它通道设置相同,欢迎测试,先做个备份,回头详细整理:
  Filename:       cc2640_pwm.c
  Revised:        $Date: 2016-10-01 11:43:11 -0700 (Sat, 01 Otc 2016) $
  Revision:       R00
  Author:         Mark Xu / QQ:2912615383
  Description:    This file contains the pwm driver for cc2640
  Copyright 2009 - 2016 Mark Xu Work Studio. All rights reserved.
#include <ti/sysbios/family/arm/cc26xx/Power.h>
#include <ti/sysbios/family/arm/cc26xx/PowerCC2650.h>
#include <driverlib/timer.h>
#include <ti/drivers/pin/PINCC26XX.h>
#include <hal_types.h>
/* the output Pin*/
#define PWM_CHAN_TIM0A_PIN                      IOID_3
#define PWM_CHAN_TIM0B_PIN                      IOID_4
/* the initial value of the duty */
#define PWM_TIM0A_INIT_DUTY                     500
#define PWM_TIM0B_INIT_DUTY                     500
/* the frequence of the PWM */
#define PWM_FREQUENCE                           250000ul
#define PWM_TIM_LOAD_VAL                        (uint32_t)(48000000ul / PWM_FREQUENCE)
#define PWM_METCH_VAL(X)                        (uint32_t)(PWM_TIM_LOAD_VAL * (1000 - X) / 1000)
PIN_Config PWMPinTable[] =
 PWM_CHAN_TIM0A_PIN | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_INPUT_DIS | PIN_DRVSTR_MAX,
 PWM_CHAN_TIM0B_PIN | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_INPUT_DIS | PIN_DRVSTR_MAX,
 PIN_TERMINATE
static PIN_Handle pinHandle;
static PIN_State pinState;
static bool PWM_Init_Flag = false;
 * @fn      board_pwm_init
 * @brief   pwm initial
 * @param   None
 * @return  None
void board_pwm_init(void)
    if(!PWM_Init_Flag)
      PWM_Init_Flag =true;
      // Initial the port
      pinHandle = PIN_open(&pinState, PWMPinTable);
      //RTOS: Enable peripheral domain and clocks for timer
      Power_setDependency(PERIPH_GPT0);
      PINCC26XX_setMux(pinHandle, PWM_CHAN_TIM0A, IOC_PORT_MCU_PORT_EVENT0);
      PINCC26XX_setMux(pinHandle, PWM_CHAN_TIM0B, IOC_PORT_MCU_PORT_EVENT1);
      TimerConfigure(GPT0_BASE, TIMER_CFG_SPLIT_PAIR | TIMER_CFG_A_PWM | TIMER_CFG_B_PWM);
      HWREG(GPT0_BASE + GPT_O_CTL)      &= ~(GPT_CTL_TAEN | GPT_CTL_TBEN); /* stop the pwm */
      HWREG(GPT0_BASE + GPT_O_TAILR)    = PWM_TIM_LOAD_VAL;
      HWREG(GPT0_BASE + GPT_O_TAMATCHR) = PWM_METCH_VAL(PWM_TIM0A_INIT_DUTY);
      HWREG(GPT0_BASE + GPT_O_TBILR)    = PWM_TIM_LOAD_VAL;
      HWREG(GPT0_BASE + GPT_O_TBMATCHR) = PWM_METCH_VAL(PWM_TIM0B_INIT_DUTY);
      HWREG(GPT0_BASE + GPT_O_CTL) |= (GPT_CTL_TAEN|GPT_CTL_TBEN);  /* start to  pwm*/
 * @fn      pwm_onoff_ctrl
 * @brief   contol the pwm
 * @param   sw - the action
 *          the data type timPwmDef defined as below:
 *          typedef enum {
 *                  TIM0A_ON=0,
 *                  TIM0A_OFF,
 *                  TIM0B_ON,
 *                  TIM0B_OFF,
 *                  TIM0AB_ON,
 *                  TIM0AB_OFF
 *                 }pwmSwDef;
 * @return  None
void pwm_onoff_ctrl(pwmSwDef sw)
  switch(sw)
    case TIM0A_ON:
      HWREG(GPT0_BASE + GPT_O_CTL) |= GPT_CTL_TAEN;
      break;
    case TIM0A_OFF:
      HWREG(GPT0_BASE + GPT_O_CTL) &= ~GPT_CTL_TAEN;
     break;
    case TIM0B_ON:
      HWREG(GPT0_BASE + GPT_O_CTL) |= GPT_CTL_TBEN;
      break;
    case TIM0B_OFF:
      HWREG(GPT0_BASE + GPT_O_CTL) &= ~GPT_CTL_TBEN;
     break;
    case TIM0AB_ON:
      break;
    case TIM0AB_OFF:
      HWREG(GPT0_BASE + GPT_O_CTL) &= ~(GPT_CTL_TAEN|GPT_CTL_TBEN);
     break;
 * @fn      pwm_set_duty
 * @brief   set the pwm duty
 * @param   chan - the channel of the pwm
 *          typedef enum{
 *                        TIM0A_CHAN=0,
 *                         TIM0B_CHAN,
 *                  timPwmDef;
 *          duty - pwm duty,the value range is :0-1000
 * @return  None
void pwm_set_duty(timPwmDef chan,uint16 duty)
  if(chan == TIM0A_CHAN)
     if(duty == 0)
       HWREG(GPT0_BASE + GPT_O_TAMATCHR) = PWM_TIM_LOAD_VAL-1;
     else if(duty == 1000)
       HWREG(GPT0_BASE + GPT_O_TAMATCHR) = (uint32)1;
     else
      HWREG(GPT0_BASE + GPT_O_TAMATCHR) = PWM_METCH_VAL(duty);
  else
     if(duty == 0)
       HWREG(GPT0_BASE + GPT_O_TBMATCHR) = PWM_TIM_LOAD_VAL-1;
       HWREG(GPT0_BASE + GPT_O_TBMATCHR) = (uint32)1;
     else
      HWREG(GPT0_BASE + GPT_O_TBMATCHR) = PWM_METCH_VAL(duty);
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
