注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
宝义的个人空间 https://home.eeworld.com.cn/space-uid-230979.html [收藏] [复制] [分享] [RSS]
日志
矩阵键盘控制模块
已有 1103 次阅读2010-5-26 06:49 |
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY mima1 IS
PORT(DATAIN:IN STD_LOGIC_VECTOR(3 DOWNTO 0);
      FUNIN:IN STD_LOGIC_VECTOR(3 DOWNTO 0);
       DFIN:IN STD_LOGIC;
       FFIN:IN STD_LOGIC;
      CLKIN:IN STD_LOGIC;
     ENLOCK:OUT STD_LOGIC;
     KEYBCD:OUT STD_LOGIC_VECTOR(15 DOWNTO 0));
 END ENTITY mima1;
 ARCHITECTURE ONE OF mima1 IS
 SIGNAL ACC,REG:STD_LOGIC_VECTOR(15 DOWNTO 0);
 SIGNAL NC:STD_LOGIC_VECTOR(2 DOWNTO 0);
 SIGNAL RR2,BB,QA,QB:STD_LOGIC;
 SIGNAL R1,R0:STD_LOGIC;
 BEGIN
 PROCESS(CLKIN)
 BEGIN
 IF CLKIN'EVENT AND CLKIN='1' THEN
R1<=R0;R0<=FFIN;
END IF;
RR2<=R1 AND NOT R0;
END PROCESS;
KEYINPUT:BLOCK IS
SIGNAL RST,D0,D1:STD_LOGIC;
BEGIN
RST<=RR2;
PROCESS(DFIN,RST)IS
BEGIN
IF RST='1'THEN
ACC<="0000000000000000";
NC<="000";
ELSE
IF DFIN'EVENT AND DFIN='1' THEN
IF NC<4 THEN
ACC<=ACC(11 DOWNTO 0)&DATAIN;
NC<=NC+1;
END IF;
END IF;
END IF;
END PROCESS;
END BLOCK KEYINPUT;
LOCKCTRL:BLOCK IS
BEGIN
PROCESS(CLKIN,FUNIN)
 BEGIN
 IF(CLKIN'EVENT AND CLKIN ='1')THEN
 IF NC=4 THEN
IF FUNIN(2)='1'THEN
REG<=ACC;
QA<='1';QB<='0';
END IF;
ELSIF FUNIN(0)='1'THEN
IF REG=ACC THEN
QA<='0';QB<='1';
END IF;
END IF;
END IF;
END PROCESS;
END BLOCK LOCKCTRL;
ENLOCK<=QA AND NOT QB;
KEYBCD<=ACC;
END ONE;
全部作者的其他最新日志
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
