注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
herway99的个人空间 https://home.eeworld.com.cn/space-uid-195345.html [收藏] [复制] [分享] [RSS]
日志
《开关电源SPICE仿真与实用设计》学习笔记_20140331
已有 3188 次阅读2014-3-31 22:00 |个人分类:电源技术
1.4.3 用线性调压器推导实用式
摘要:在本节中,通过公式的推导得出了线性稳压器中误差放大器的增益与稳压器精度和电源抑制能力的关系,解决了新手一些常见的问题。
In Fig. 1-5, Vout(s) is compared to Vref(s) via a resistive divider affected by a transfer ratio of a. H(0) illustrates the static or dc relationship between the output voltage and the control voltage Vc, e.g., Vc=5.77 V to obtain Vout=5 V in this example. The theoretical dc voltage(s=0, but we purposely avoided this subscript below for the sake of clarity) you would expect from such a configuration is
 (1.8)
     Unfortunately, the whole gain chain and various impedances will affect this value. With a few lines of algebra, we can write the static output voltage definition (again, s=0) simply by following the meshes:
     The static error on the output, actually the deviation between what we really want and what we finally obtain, is derived by subtracting the Vout expression [Eq. (1-10)] from Eq. (1-8):
     If we consider Rs,OL<< Rload, then Eq. (1-11) simplifies to
     which equals zero if
    From this equation, we can see that increasing the dc gain, G(0), helps diminish the static error which finally affects our output voltage precision.Another important parameter influenced by the loop gain is the closed-loop output impedance. The output impedance of a system can be derived in different manners. As Fig. 1-4b has shown, our closed-loop generator can now be reduced to its Thévenin equivalent, that is, a voltage source Vth[Vout measured without any load, or Rload= in Eq. (1-10)], followed by an output impedance Rs,CL, which we actually look for. One option consists of calculating a resistor RLX which, once wired between the output and ground, will reduce Vout=Vth to Vout=Vth/2  When this occurs, RLX simply equals Rs,CL(we have built a simple resistive divider with equal resistors). We can quickly manipulate Eq. (1-10), assuming  Rload=:  Vth/2=Vout(RLX) or “What value of RLX will divide the Thévenin voltage by 2?”
      If we call  the staticloop gain T, then the closed-loop output impedance is
Equation (1-14) teaches us different things :
1. If we have a large dc loop gain T(0), then Rs,CL is close to zero.
2. Because we have compensated the feedback return path G(s) for stability purposes, when the loop gain T(s) reduces as the frequency increases, Rs,CL starts to rise: an impedance whose module grows with frequency looks like an inductance! We will come back to this result later.
3. When the loop gain T(s) has dropped to zero, then the system exhibits an output impedance that is the same as in the lack of feedback, Rs,OL: the system runs open-loop.
In this example, we purposely did not account for an input voltage perturbation. This assumption is valid for bipolar transistors as the weak influence of the Early effect makes them good current generators, almost independent from their Vce variations. However, when Vout and Vin are close to each other, the transistor becomes a closed switch rather than a current source! Therefore, the input voltage starts to play a role. Let us redraw the Fig. 1-5 sketch, including the input voltage contribution. As drawn in Fig. 1-6, the term krepresents the open-loop audio susceptibility, denoted As,OL. It represents the input voltage contribution to the output, also called input ripple rejection.
Let’s now write the mesh equations as we did previously:
     Again, operating with a large dc gain ensures an excellent rejection of the input voltage ripple (100 or 120 Hz for full-wave rectification). When T(s) reduces in the high-frequency domain,the system runs open-loop. Please note that we purposely selected a positive polarity for k, but a negative value could also have been chosen. It actually depends on the topology under study.
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
