注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
shangdawei的个人空间 https://home.eeworld.com.cn/space-uid-180876.html [收藏] [复制] [分享] [RSS]
日志
How Do Perform STD_LOGIC_VECTOR Addition Using IEEE.NUMERIC_STD?
已有 2064 次阅读2010-12-30 21:45
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
    subtype slv is std_logic_vector;
  signal dpll_counter : std_logic_vector( 4 downto 0 );
        dpll_counter <= dpll_counter + "00001";
        dpll_counter <= unsigned(dpll_counter) + 1;
        dpll_counter <= std_logic_vectorUNSIGNED(dpll_counter) + 1 );
        dpll_counter <= slv( unsigned(dpll_counter) + 1 );
signal count : unsigned(input'range);
count <= unsigned(input);
count <= count + 1;
output <= slv(count);
Or define count as a natural:
signal input, output : std_logic_vector( 4 downto 0);
signal count : natural range 0 to 2**input'length-1;
count <= count + 1; -- much faster rtl simulation
output <= slv(to_unsigned(count, output'length));
count <= to_integer(unsigned(input));
signal count : natural range 0 to 2**numbits-1; -- numbits wide count
Thus count - 1 < 0 is still possible, even though count < 0 is not.
This is an easy way to extract the carry condition in a down counter:
if count - 1 < 0 then -- carry bit set
  count <= start_value; -- reload
else
  count <= count - 1; -- update
end if;
The synthesizer (XST, Quartus, Synplify-Pro, Precision, even the old
synopsys DCFPGA) will automatically share the decrement between the
comparison and the update, and use the next bit (the sign bit) to
control the reload or update.
The same sort of trick works for overflow in an up counter too.
So I synthesized a couple versions to see what XST (ISE8.2) does (into
an XC2VP7), checking the results with fpga_editor. I first had to use
fairly large counters or it would not necessarily use the carry chain,
and I wanted to see how that was used.
So the above mentioned:
else
end if;
That created two parallel sets of LUTs, one with the counter itself, and
one that simply calculates count-1 using a carry chain. It is the carry
output of this second chain that triggers reloading of the counter.
Next:
if count = 0 then -- carry bit set
else
end if;
That created a single chain for the counter, and then in LUTs it
implemented ~count1*~count2*~count3... , with the output of that
triggering the load.
The second method actually uses less logic than the first, but neither
was ideal. I must say, I am not impressed with XST synthesis of
something so basic as a counter :-(
In the numeric_std package there is a type called "unsigned" (and
another called "signed") for doing math. This allows you keep the
concept of a signed and unsigned number separate. You would do it like
this:
signal count : unsigned ( 7 downto 0);
count <= count + 1;
If you really need it in std_logic_vector you can say:
countslv <= std_logic_vector (count);
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
