注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
LitchiCheng的个人空间 https://home.eeworld.com.cn/space-uid-1003127.html [收藏] [复制] [分享] [RSS]
日志
ROS2 中 TF 变换发布与订阅:实现 base_link 和 test_link 实时可视化显示
已有 319 次阅读2025-2-23 22:10 |个人分类:ROS2
视频讲解
安装环境依赖
sudo apt-get install ros-humble-tf2-ros ros-humble-tf2-geometry-msgs ros-humble-tf-transformations
创建一个包名为tf_test_pkg的包
ros2 pkg create --build-type ament_python tf_test_pkg --dependencies rclpy tf2_ros geometry_msgs
依赖为tf2_ros,geometry_msgs
在tf_test_pkg/tf_test_pkg中创建tf_publisher.py
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import TransformStamped
import tf2_ros
import math
class TFPublisher(Node):
    def __init__(self):
        super().__init__('tf_publisher')
        self.tf_broadcaster = tf2_ros.TransformBroadcaster(self)
        self.timer = self.create_timer(0.1, self.broadcast_tf)
        self.pitch = 0.0
    def broadcast_tf(self):
        t = TransformStamped()
        t.header.stamp = self.get_clock().now().to_msg()
        t.header.frame_id = '/base_link'
        t.child_frame_id = '/test_link'
        # 设置平移
        t.transform.translation.x = 1.0
        t.transform.translation.y = 0.0
        t.transform.translation.z = 0.0
        # 增加pitch角度
        self.pitch += 0.2
        if self.pitch > 2 * math.pi:
            self.pitch -= 2 * math.pi
        # 设置旋转(仅pitch变化)
        from tf_transformations import quaternion_from_euler
        q = quaternion_from_euler(0, self.pitch, 0)
        t.transform.rotation.x = q[0]
        t.transform.rotation.y = q[1]
        t.transform.rotation.z = q[2]
        t.transform.rotation.w = q[3]
        # 发布TF变换
        self.tf_broadcaster.sendTransform(t)
def main(args=None):
    rclpy.init(args=args)
    tf_publisher = TFPublisher()
    rclpy.spin(tf_publisher)
    tf_publisher.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
同样的,创建tf_subscriber.py
import rclpy
import tf2_ros
from tf2_ros.buffer import Buffer
from tf2_ros.transform_listener import TransformListener
class TFSubscriber(Node):
    def __init__(self):
        super().__init__('tf_subscriber')
        self.tf_buffer = Buffer()
        self.tf_listener = TransformListener(self.tf_buffer, self)
        self.timer = self.create_timer(1.0, self.lookup_transform)
    def lookup_transform(self):
        try:
            trans = self.tf_buffer.lookup_transform(
                'base_link', 'test_link', rclpy.time.Time())
            self.get_logger().info(f"Translation: {trans.transform.translation}")
            self.get_logger().info(f"Rotation: {trans.transform.rotation}")
        except (tf2_ros.LookupException, tf2_ros.ConnectivityException, tf2_ros.ExtrapolationException):
            self.get_logger().warn("Could not find transform between /base_link and /test_link")
    tf_subscriber = TFSubscriber()
    rclpy.spin(tf_subscriber)
    tf_subscriber.destroy_node()
    rclpy.shutdown()
    main()
修改setup.py,增加内容如下:
entry_points={
        'console_scripts': [
            'tf_publisher = tf_test_pkg.tf_publisher:main',
            'tf_subscriber = tf_test_pkg.tf_subscriber:main',
编译运行
colcon build --packages-select tf_test_pkg
source install/setup.bash
ros2 run tf_test_pkg tf_publisher
ros2 run tf_test_pkg tf_subscriber
rviz2配置
设置固定坐标系
启动 Rviz 后,在 Rviz 窗口左侧的 “Displays” 面板中,找到 “Global Options” 部分,点击 “Fixed Frame” 右侧的下拉框,选择 /base_link 作为固定坐标系。这一步很关键,因为 Rviz 会以固定坐标系为参考来显示其他坐标系的位置和姿态。
添加 TF 显示插件
在 Rviz 窗口左侧 “Displays” 面板的上方,点击 “Add” 按钮,在弹出的 “Add Display” 对话框中,选择 “TF” 选项,然后点击 “OK”。此时,“Displays” 面板中会新增一个 “TF” 条目。
调整 TF 显示设置
在 “Displays” 面板中展开 “TF” 条目
  • Marker Scale:用于调整坐标系箭头的大小。你可以根据实际情况增大或减小该值,使显示效果更清晰。
  • Show Axes:勾选该选项会显示每个坐标系的坐标轴(X 轴为红色,Y 轴为绿色,Z 轴为蓝色),方便直观地了解坐标系的方向。
  • Show Names:勾选此选项会在每个坐标系旁边显示其名称(如 /base_link 和 /test_link),便于识别不同的坐标系。
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
