注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
dql2016的个人空间 https://home.eeworld.com.cn/space-uid-676625.html [收藏] [复制] [分享] [RSS]
日志
FRDM-KW41Z入门——SPI驱动微雪电子纸屏
已有 2189 次阅读2017-5-26 12:08 |个人分类:物联网
基于例程\SDK_2.2_FRDM-KW41Z\boards\frdmkw41z\driver_examples\dspi\polling_transfer修改,SPI可以使用轮询或者DMA模式。
使用的是微雪1.54英寸电子纸屏幕,6根线驱动。
接线如下:
电子纸屏         FRDM-KW41Z的Arduino UNO接口名       管脚名             信号名
BUSY               D2                                                          PTC19             忙检测,低电平有效
RST                 D3                                                          PTC16              复位,低电平有效
DC                   D4                                                          PTC4                数据/指令
CS                   D10                                                         PTA19               SPI1片选
CLK                 D13                                                         PTA18                SPI1时钟
DIN                 D11                                                          PTA16                SPI1主机输出
首先配置管脚:
在pin_mux.c文件添加代码:
[C] 纯文本查看 复制代码
* Copyright (c) 2015, Freescale Semiconductor, Inc.
* Copyright 2016-2017 NXP
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* o Redistributions of source code must retain the above copyright notice, this list
*   of conditions and the following disclaimer.
* o Redistributions in binary form must reproduce the above copyright notice, this
*   list of conditions and the following disclaimer in the documentation and/or
*   other materials provided with the distribution.
* o Neither the name of the copyright holder nor the names of its
*   contributors may be used to endorse or promote products derived from this
*   software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
* ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* TEXT BELOW IS USED AS SETTING FOR THE PINS TOOL *****************************
PinsProfile:
- !!product 'Pins v2.0'
- !!processor 'MKW41Z512xxx4'
- !!package 'MKW41Z512VHT4'
- !!mcu_data 'ksdk2_0'
- !!processor_version '0.0.0'
* BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR THE PINS TOOL ***
#include "fsl_common.h"
#include "fsl_port.h"
#include "pin_mux.h"
#define PIN6_IDX                         6u   /*!< Pin number for pin 6 in a port */
#define PIN7_IDX                         7u   /*!< Pin number for pin 7 in a port */
#define PIN16_IDX                       16u   /*!< Pin number for pin 16 in a port */
#define PIN17_IDX                       17u   /*!< Pin number for pin 17 in a port */
#define PIN18_IDX                       18u   /*!< Pin number for pin 18 in a port */
#define PIN19_IDX                       19u   /*!< Pin number for pin 19 in a port */
#define SOPT5_LPUART0RXSRC_LPUART_RX  0x00u   /*!< LPUART0 Receive Data Source Select: LPUART_RX pin */
BOARD_InitPins:
- options: {coreID: singlecore, enableClock: 'true'}
- pin_list:
  - {pin_num: '42', peripheral: LPUART0, signal: RX, pin_signal: TSI0_CH2/PTC6/LLWU_P14/XTAL_OUT_EN/I2C1_SCL/UART0_RX/TPM2_CH0/BSM_FRAME}
  - {pin_num: '43', peripheral: LPUART0, signal: TX, pin_signal: TSI0_CH3/PTC7/LLWU_P15/SPI0_PCS2/I2C1_SDA/UART0_TX/TPM2_CH1/BSM_DATA}
  - {pin_num: '45', peripheral: SPI0, signal: SCK, pin_signal: TSI0_CH4/PTC16/LLWU_P0/SPI0_SCK/I2C0_SDA/UART0_RTS_b/TPM0_CH3}
  - {pin_num: '46', peripheral: SPI0, signal: SOUT, pin_signal: TSI0_CH5/PTC17/LLWU_P1/SPI0_SOUT/I2C1_SCL/UART0_RX/BSM_FRAME/DTM_RX}
  - {pin_num: '47', peripheral: SPI0, signal: SIN, pin_signal: TSI0_CH6/PTC18/LLWU_P2/SPI0_SIN/I2C1_SDA/UART0_TX/BSM_DATA/DTM_TX}
  - {pin_num: '48', peripheral: SPI0, signal: PCS0_SS, pin_signal: TSI0_CH7/PTC19/LLWU_P3/SPI0_PCS0/I2C0_SCL/UART0_CTS_b/BSM_CLK/BLE_RF_ACTIVE}
  - {pin_num: '4', peripheral: SPI1, signal: SOUT, pin_signal: TSI0_CH10/PTA16/LLWU_P4/SPI1_SOUT/TPM0_CH0}
  - {pin_num: '5', peripheral: SPI1, signal: SIN, pin_signal: TSI0_CH11/PTA17/LLWU_P5/RF_RESET/SPI1_SIN/TPM_CLKIN1}
  - {pin_num: '6', peripheral: SPI1, signal: SCK, pin_signal: TSI0_CH12/PTA18/LLWU_P6/SPI1_SCK/TPM2_CH0}
  - {pin_num: '7', peripheral: SPI1, signal: PCS0_SS, pin_signal: TSI0_CH13/ADC0_SE5/PTA19/LLWU_P7/SPI1_PCS0/TPM2_CH1}
/*FUNCTION**********************************************************************
* Function Name : BOARD_InitPins
* Description   : Configures pin routing and optionally pin electrical features.
*END**************************************************************************/
void BOARD_InitPins(void) {
  CLOCK_EnableClock(kCLOCK_PortA);                           /* Port A Clock Gate Control: Clock enabled */
  CLOCK_EnableClock(kCLOCK_PortC);                           /* Port C Clock Gate Control: Clock enabled */
  PORT_SetPinMux(PORTA, PIN16_IDX, kPORT_MuxAlt2);           /* PORTA16 (pin 4) is configured as SPI1_SOUT */
  PORT_SetPinMux(PORTA, PIN17_IDX, kPORT_MuxAlt2);           /* PORTA17 (pin 5) is configured as SPI1_SIN */
  PORT_SetPinMux(PORTA, PIN18_IDX, kPORT_MuxAlt2);           /* PORTA18 (pin 6) is configured as SPI1_SCK */
  PORT_SetPinMux(PORTA, PIN19_IDX, kPORT_MuxAlt2);           /* PORTA19 (pin 7) is configured as SPI1_PCS0 */
        PORT_SetPinMux(PORTC, 4u,  kPORT_MuxAsGpio);            /* PORTC4 (pin 40) is configured as GPIOC4 */
  PORT_SetPinMux(PORTC, 16u, kPORT_MuxAsGpio);            /* PORTC16 (pin 45) is configured as GPIOC16 */
  PORT_SetPinMux(PORTC, PIN6_IDX, kPORT_MuxAlt4);            /* PORTC6 (pin 42) is configured as UART0_RX */
  PORT_SetPinMux(PORTC, PIN7_IDX, kPORT_MuxAlt4);            /* PORTC7 (pin 43) is configured as UART0_TX */
  SIM->SOPT5 = ((SIM->SOPT5 &
    (~(SIM_SOPT5_LPUART0RXSRC_MASK)))                        /* Mask bits to zero which are setting */
      | SIM_SOPT5_LPUART0RXSRC(SOPT5_LPUART0RXSRC_LPUART_RX) /* LPUART0 Receive Data Source Select: LPUART_RX pin */
* EOF
主函数:
[C] 纯文本查看 复制代码
* Copyright (c) 2013 - 2015, Freescale Semiconductor, Inc.
#include "fsl_device_registers.h"
#include "fsl_debug_console.h"
#include "fsl_dspi.h"
#include "board.h"
#include "clock_config.h"
#include "EPD_drive.h"
#include "EPD_drive_gpio.h"
#include "Display_Lib.h"
* Definitions
#define DSPI_MASTER_CLK_SRC DSPI1_CLK_SRC
#define DSPI_MASTER_CLK_FREQ CLOCK_GetFreq(DSPI1_CLK_SRC)
dspi_master_handle_t g_m_handle; //global variable
* Prototypes
* Variables
* Code
void delay_ms(unsigned long xms)
          volatile uint32_t i = 0;
        while(xms--)
    for (i = 0; i < 4000; ++i)
        __asm("NOP"); /* delay */
* @brief Main function
int main(void)
                int tt=0;
                //Define a digital output pin configuration
                gpio_pin_config_t out_config =
                        kGPIO_DigitalOutput,
                        0,
         //Define a digital intput pin configuration
                gpio_pin_config_t in_config =
                        kGPIO_DigitalInput,
                        0,
                /* Input pin PORT configuration */
                port_pin_config_t config = {
                kPORT_PullUp,
                kPORT_FastSlewRate,
                kPORT_PassiveFilterDisable,
                kPORT_LowDriveStrength,
                kPORT_MuxAsGpio,
    BOARD_InitPins();
    BOARD_BootClockRUN();
    BOARD_InitDebugConsole();
                        /* Sets the configuration */
                PORT_SetPinConfig(PORTC, 19, &config);
                FGPIO_PinInit(FGPIOC, 19, &in_config);//D2
                GPIO_PinInit(RST_GPIO_Port, RST_Pin, &out_config);//D3
                GPIO_PinInit(DC_GPIO_Port, DC_Pin, &out_config);//D4
    PRINTF("DSPI polling to drive the WaveShare 1.54 inch e-Paper example start.\r\n");
    uint32_t srcClock_Hz;
    dspi_master_config_t masterConfig;
    /* Master config */
    masterConfig.whichCtar = kDSPI_Ctar0;
    masterConfig.ctarConfig.baudRate = 16000000U;
    masterConfig.ctarConfig.bitsPerFrame = 8;
    masterConfig.ctarConfig.cpol = kDSPI_ClockPolarityActiveLow;
    masterConfig.ctarConfig.cpha = kDSPI_ClockPhaseFirstEdge;
    masterConfig.ctarConfig.direction = kDSPI_MsbFirst;
    masterConfig.ctarConfig.pcsToSckDelayInNanoSec =1;//1000000000U / masterConfig.ctarConfig.baudRate
    masterConfig.ctarConfig.lastSckToPcsDelayInNanoSec = 1;
    masterConfig.ctarConfig.betweenTransferDelayInNanoSec = 1;
    masterConfig.whichPcs = kDSPI_Pcs0;
    masterConfig.pcsActiveHighOrLow = kDSPI_PcsActiveLow;
    masterConfig.enableContinuousSCK = false;
    masterConfig.enableRxFifoOverWrite = false;
    masterConfig.enableModifiedTimingFormat = false;
    masterConfig.samplePoint = kDSPI_SckToSin0Clock;
    srcClock_Hz = DSPI_MASTER_CLK_FREQ;
    DSPI_MasterInit(SPI1, &masterConfig, srcClock_Hz);
    DSPI_MasterTransferCreateHandle(SPI1, &g_m_handle, NULL, NULL);
                PRINTF("srcClock=%d MHz\r\n",srcClock_Hz/1000000);
                PRINTF("sysClock=%d MHz\r\n",CLOCK_GetFreq(kCLOCK_CoreSysClk)/1000000);
    /* Start master transfer */
                Dis_Clear_full();
                delay_ms(500);
                Dis_Clear_full();
                delay_ms(500);
                Dis_Clear_part();
                delay_ms(500);
                Dis_Clear_part();
                Dis_showNum64128(32,48,00);
                EPD_Dis_Part(0,0+1*24-1,0,0+48-1,Font2448[13],1);//p
                EPD_Dis_Part(0+1*24,0+2*24-1,0,0+48-1,Font2448[12],1);//x
                EPD_Dis_Part(0+2*24,0+3*24-1,0,0+48-1,Font2448[11],1);//n
                EPD_Dis_Part(0+3*24,0+4*24-1,0,0+48-1,Font2448[16],1);//z
                EPD_Dis_Part(0+4*24,0+5*24-1,0,0+48-1,Font2448[1],1);//1
                EPD_Dis_Part(0+5*24,0+6*24-1,0,0+48-1,Font2448[4],1);//4
                EPD_Dis_Part(0+6*24,0+7*24-1,0,0+48-1,Font2448[15],1);//w
                EPD_Dis_Part(0+7*24,0+8*24-1,0,0+48-1,Font2448[14],1);//k
    while (1)
                        tt++;
                        if(tt>99)
                                tt=0;
                        Dis_showNum64128(32,48,tt);
                        delay_ms(500);
若使用DMA则定义句柄dspi_master_handle_t,在上面主函数里绑定SPI1,然后在接口函数调用DSPI_MasterTransferNonBlocking发送数据;不使用DMA的话调用DSPI_MasterTransferBlocking即可。
EPD_drive_gpio.c接口文件:
[C] 纯文本查看 复制代码
dspi_transfer_t masterXfer;
extern dspi_master_handle_t g_m_handle; //global variable
void SPI_Write(unsigned char value)
//        status_t ret=kStatus_Fail;
         uint8_t TxData=value;
         masterXfer.txData=&TxData;
         masterXfer.dataSize=1;
         masterXfer.configFlags = kDSPI_MasterPcs0;//kDSPI_MasterCtar0 | kDSPI_MasterPcs0 | kDSPI_MasterPcsContinuous
         //DSPI_MasterTransferBlocking(SPI1, &masterXfer);
        DSPI_MasterTransferNonBlocking(SPI1, &g_m_handle,&masterXfer);
//         ret=DSPI_MasterTransferBlocking(SPI1, &masterXfer);
//        if(ret!=kStatus_Success)
//                PRINTF("ret=%d \r\n",ret);
把2个驱动文件添加到工程:
字模使用zimo221软件:
需要左右转换和反白。
驱动文件附件:
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
