注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
liongt的个人空间 https://home.eeworld.com.cn/space-uid-53096.html [收藏] [复制] [分享] [RSS]
日志
LM3开发笔记_8.Telnet协议的串口服务器
已有 2495 次阅读2010-12-25 22:18
快到年关了,项目上非常忙,很久没来了。今天抽空把俺的串口服务器Telnet协议部分整理了一下。
串口服务器可以将telnet发送的指令通过串口转发到对应的设备,来获取设备状态和控制设备。比如查看设备的电流,电压和温度等等。
直接上代码,有问题可跟贴。
// 握手字符串
#define HANDSHAKE "Serial Server v1.0 Telnet System!\r\n"
// Telnet初始化
void TelnetCmd_init(void)
 struct tcp_pcb *pcb;
 /* Create a new TCP control block  */
 pcb = tcp_new();
 /* Using IP_ADDR_ANY allow the pcb to be used by any local interface */
 tcp_bind(pcb, IP_ADDR_ANY, 23);
 /* Set the connection to the LISTEN state */
 pcb = tcp_listen(pcb);
 /* Specify the function to be called when a connection is established */
 tcp_accept(pcb, TelnetCmd_accept);
// Telnet新连接处理函数
static err_t TelnetCmd_accept(void *arg, struct tcp_pcb *pcb, err_t err)
 /* Tell LwIP to associate this structure with this connection. */
 tcp_arg(pcb, mem_calloc(sizeof(CMDSTRUCT), 1));
 /* Configure LwIP to use our call back functions. */
 tcp_err(pcb, TelnetCmd_conn_err);
 tcp_recv(pcb, TelnetCmd_recv);
 tcp_write(pcb, HANDSHAKE, strlen(HANDSHAKE), TCP_WRITE_FLAG_COPY);
 return ERR_OK;
// Telnet接收处理函数
static err_t TelnetCmd_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
 struct pbuf *q;
 CMDSTRUCT *pReceiveCmd;
 CMDSTRUCT SendCmd;
 static bool bAccepting = FALSE;
 int done;
 char *Word;
 char ch;
 int i;
 pReceiveCmd = (CMDSTRUCT *)arg;
 /* We perform here any necessary processing on the pbuf */
 if (p != NULL)
  tcp_recved(pcb, p->tot_len);
  if(!pReceiveCmd)
   pbuf_free(p);
   return ERR_ARG;
  done = 0;
  for(q=p; q != NULL; q = q->next)
   Word = q->payload;
   for(i=0; i<q->len && !done; i++)
    ch = Word;
    if('$' == ch)
     bAccepting = TRUE;
     pReceiveCmd->length = 0;
    if(bAccepting)
     if(pReceiveCmd->length < CMDBUFFERSIZE)
      pReceiveCmd->bytes[pReceiveCmd->length++] = ch;
     if(';' == ch || pReceiveCmd->length >= CMDBUFFERSIZE)
      bAccepting = FALSE;
      done = 1;
  if(done)
   if(UartApp_SendData(pReceiveCmd,&SendCmd))
    tcp_write(pcb, SendCmd.bytes, SendCmd.length, TCP_WRITE_FLAG_COPY);
  /* End of processing, we free the pbuf */
  pbuf_free(p);
 else if (err == ERR_OK)
  mem_free(pReceiveCmd);
  return tcp_close(pcb);
 return ERR_OK;
// Telnet错误处理
static void TelnetCmd_conn_err(void *arg, err_t err)
 CMDSTRUCT *cmd;
 cmd = (CMDSTRUCT *)arg;
 mem_free(cmd);
WebServer部分没有做完,时间不够了!
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
