1、uart 4如果使用dma方式进行数据收发,需要打开GPIOC 的clock,以及DMA2的clock(stm32f107的dma有两个,dma1和dma2,此部分uart4_tx和uart4_rx映射到的是dma2的channel 5和dma2的channel 3;
#include "GlobalVar.h"
#include "usart.h"
#include "stm32f10x_dma.h"
#include "string.h"
#define UART4_DMA_BUF_NUM 8
unsigned char receiveBuf[8];
unsigned char receiveCount;
static uint8_t uart4_rxdata[UART4_DMA_BUF_NUM];
USART_RECV_CALLBACK _usart_recv_callbacks[6] = { 0 };
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
static void uart4_trx_dma_config(void)
DMA_InitTypeDef DMA_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2,ENABLE);
DMA_DeInit(DMA2_Channel3);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&UART4->DR;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)uart4_rxdata;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = UART4_DMA_BUF_NUM;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA2_Channel3, &DMA_InitStructure);
DMA_ITConfig( DMA2_Channel3, DMA_IT_TC, ENABLE );
DMA_ITConfig(DMA2_Channel3,DMA_IT_TE,ENABLE);
USART_DMACmd(UART4,USART_DMAReq_Rx,ENABLE);
DMA_Cmd(DMA2_Channel3, ENABLE);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Channel3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Channel5_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
uint32_t USART_Configuration(const struct USARTDefine* configs, uint16_t len) {
uint16_t u = 0;
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
for( u = 0; u < len; ++u) {
struct USARTDefine config = configs[u];
if( config.usartdef == UART5 ) {
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART5, ENABLE);
_usart_recv_callbacks[BOARD_USART_1] = config.recvcallback;
} else if(config.usartdef == UART4 ) {
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);
_usart_recv_callbacks[BOARD_USART_2] = config.recvcallback;
GPIO_InitStructure.GPIO_Pin = config.pin_of_txd;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(config.pin_of_txd_group, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = config.pin_of_rxd;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(config.pin_of_rxd_group, &GPIO_InitStructure);
USART_InitStructure.USART_BaudRate = config.bandrate;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl =
USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(config.usartdef, &USART_InitStructure);
if( config.recvcallback != 0 ) {
USART_ITConfig(config.usartdef,USART_IT_RXNE,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
USART_Cmd(config.usartdef, ENABLE);
if(config.usartdef == UART4 ){
//USART_ITConfig(UART4,USART_IT_IDLE,ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
USART_ClearFlag(UART4,USART_FLAG_IDLE);
USART_ClearFlag(UART4,USART_FLAG_TC);
uart4_trx_dma_config();
return 0;
void _usart_nvic_config(uint32_t usart_irqn, uint32_t preemptionpriority,
uint32_t subpriority) {
NVIC_InitStructure.NVIC_IRQChannel = usart_irqn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = preemptionpriority;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = subpriority;
void _usart_comm_irqhandler(USART_TypeDef* usarttypedef,enum BOARD_USART_TYPE usart_type) {
unsigned char recv_char;
if (USART_GetFlagStatus(usarttypedef, USART_FLAG_RXNE) != RESET) {
USART_ClearITPendingBit(usarttypedef, USART_IT_RXNE);
recv_char = USART_ReceiveData(usarttypedef);
if (_usart_recv_callbacks[usart_type] != NULL)
_usart_recv_callbacks[usart_type](usart_type, recv_char);
void USART1_IRQHandler(void) {
_usart_comm_irqhandler(USART1, BOARD_USART_1);
void USART2_IRQHandler(void) {
_usart_comm_irqhandler(USART2, BOARD_USART_2);
void _usart_sendchar(USART_TypeDef* usart_typedef, uint8_t sChar) {
USART_SendData(usart_typedef, (uint8_t) sChar);
while (USART_GetFlagStatus(usart_typedef, USART_FLAG_TXE) == RESET) {
void _usart_sendstring(USART_TypeDef* usart_typedef, uint8_t* string, uint8_t length) {
uint8_t* p = string;
uint8_t len;
if(length==0){
while( *p++ != '\0' ){
USART_SendData(usart_typedef, (uint8_t)(*p));
else
for(len=0;len<length;len++){
p++;
PUTCHAR_PROTOTYPE {
USART_SendData(USART1, (u8) ch);
while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
return ch;
串口中断 idle中断
void UART4_IRQHandler(void)
uint16_t dma_len;
uint32_t i;
uint16_t dmadatalength;
if(USART_GetITStatus(UART4,USART_IT_IDLE)!=RESET)
DMA_Cmd(DMA2_Channel3,DISABLE);
dma_len = DMA_GetCurrDataCounter(DMA2_Channel3);
dmadatalength = UART4_DMA_BUF_NUM - dma_len;
DMA_ClearFlag(DMA2_FLAG_GL3 | DMA2_FLAG_TC3 | DMA2_FLAG_TE3 | DMA2_FLAG_HT3);//
DMA_SetCurrDataCounter(DMA2_Channel3,UART4_DMA_BUF_NUM);
DMA_Cmd(DMA2_Channel3,ENABLE);
usart_dma_dataprocess(uart4_rxdata,dmadatalength);
i = UART4->SR;
i = UART4->DR;
// uart4 rx
void DMA2_Channel3_IRQHandler(void)
DMA_ClearITPendingBit(DMA2_IT_TC3);
DMA_ClearITPendingBit(DMA2_IT_TE3);
usart_dma_dataprocess(uart4_rxdata,UART4_DMA_BUF_NUM);
// uart4 tx
void DMA2_Channel5_IRQHandler(void)
if(DMA_GetITStatus(DMA2_IT_TC5)){
DMA_ClearITPendingBit(DMA2_IT_GL5);
void uart_dma_sendNbytes(uint8_t *buffer,uint16_t buffersize)
DMA_DeInit(DMA2_Channel5);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(UART4->DR);
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)buffer;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = buffersize;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_Init(DMA2_Channel5, &DMA_InitStructure);
DMA_ITConfig( DMA2_Channel5, DMA_IT_TC, ENABLE );
DMA_ITConfig(DMA2_Channel5,DMA_IT_TE,ENABLE);
USART_DMACmd(UART4,USART_DMAReq_Tx,ENABLE);
DMA_Cmd(DMA2_Channel5, ENABLE);
void usart_dma_dataprocess(uint8_t *data,uint16_t datalen){
uart_dma_sendNbytes(data,datalen);
-----------------------------以上是.c文件--------------------------------------------
----------------------------------------以上是.h文件--------------------------------------
(uart idle是一个帧结束后,出现中断,而dma的中断则是定义的dmabuffer的长度到,进入中断,如果发送的帧长度大于定义的buffer长度,需要在程序中进行重新组帧操作)
因为dma中断需要接收长度到达定义的长度时,才可以获取接收到的数据,此时可能帧已经结束,但是dma中断没有触发,有效的帧无通知信息告诉用户处理,但是如果使用uart的idle,则可以进入idle 中断,进行数据的帧处理。如果发送的数据长度大于dmabuffer的长度,也可以进行组帧操作结合idle中断进行。
