注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
cyanysys的个人空间 https://home.eeworld.com.cn/space-uid-482952.html [收藏] [复制] [分享] [RSS]
日志
毕业设计最后关头,十万火急呀~~~~
已有 1614 次阅读2013-5-26 19:13
求大神帮我看看程序,我是用超声波模块测距,并将测得距离通过串口在组态王上显示...并且通过数码管显示出来。问题是按照这个程序,数码管不亮(这让我非常不解),且和组态王通信有问题,应该是定时器1中断时间的问题,不知道设置多少合适呀?
#include
#include
#define uchar unsigned char
#define uint unsigned int
//#define N 800
sbit SDATA_595 = P2^5; //串行移位输入
sbit SHcp_595 = P2^7; //移位寄存器时钟输入SHcp
sbit STcp_595 = P2^6;   //存储寄存器时钟输入STcp
sbit fengmingqi=P2^0;
unsigned int  time=0;
unsigned int  timer=0;
unsigned int  t=0;
//unsigned char  z=100;
unsigned char posit=0;
unsigned long S=0;
bit      flag =0;
unsigned char const discode[] ={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xBF,0xff/*-*/};
unsigned char const positon[3]={0x10,0x08,0x04};
unsigned char disbuff[4]={0,0,0,0,};
sbit  RX=P1^2;
sbit  TX=P1^3;
sbit  Q1=P1^4;
sbit  Q2=P1^0;
sbit  Q3=P1^1;
sbit  K1=P1^7;
sbit  K2=P1^6;
sbit  K3=P1^5;
sbit  K4=P2^1;
sbit  S1=P2^2;
sbit  S2=P2^3;
unsigned char rec[50];
unsigned char code error[]={0x40,0x30,0x46,0x2a,0x2a,0x37,0x36,0x0d};
unsigned char send[]={0x40,0x30,0x46,0x30,0x31,0x00,0x00,0x00,0x00,0x0d};
unsigned char i;
unsigned char ath(unsigned char,unsigned char);
unsigned int hta(unsigned char);
//void uart(void);
void delay(uint);
/*-----------延时子程序---------*/
void delay(uint z)
        uint f;
        for(;z>0;z--)
        for(f=100;f>0;f--);
void OUT_595(void)
        STcp_595 = 0;
        _nop_();
        _nop_();
        STcp_595=1; //上升沿将数据送到输出锁存器
        _nop_();
        _nop_();
        STcp_595 = 0 ;
void WR_595(uchar x)
        uchar temp;
        uchar j;
        temp = x;
        SHcp_595 = 0;
        for (j=0; j<8; j++)
                temp = temp<<1;
                SDATA_595 = CY;
                SHcp_595 = 1; //上升沿发生移位
                _nop_();
                _nop_();
                SHcp_595 = 0;
                _nop_();
                _nop_();
        OUT_595();
/*void baojing()
                uchar x,i;
                x=0xfe;
                fengmingqi=1;
            for(i=0;i<8;i++)
                        WR_595(x);
                        delay(N);
                        x=(x<<1)|0x01;
                        delay(N);
void Display(void)                                 //扫描数码管
                if(++posit>=3)
                posit=0;
                P3=positon[posit] ;
        if(posit==1)
                P0=(discode[disbuff[posit]])&0x7f;
        else
         P0=discode[disbuff[posit]];
void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=130-(time*17)/100;     //算出来是CM x10
         if((S>=700)||flag==1) //超出测量范围显示“-”
          flag=0;
          disbuff[0]=10;           //“-”
          disbuff[1]=10;           //“-”
          disbuff[2]=10;           //“-”
         else
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%100%10;
         if(S<=55||S>=95)
            WR_595(0x00);
                 fengmingqi=1;
         else
                 WR_595(0xff);
                 fengmingqi=0;
         if(K1==1&&K2==1&&S<=50){Q1=0;Q2=1;}
         if(K1==1&&K2==0&&S<=50){Q2=0;Q1=1;}
         if(K1==1&&S>=100){Q1=1;Q2=1;}
         if(K1==1&&S1==0&&S2==1){Q3=0;t=1;}
         if(K1==1&&S1==0&&S2==0&&t==1)Q3=0;
         if(K1==1&&S1==0&&S2==0&&t==0)Q3=1;
         if(K1==1&&S1==1&&S2==0){Q3=1;t=0;}
         if(K1==0&&K3==1){Q1=1;Q2=1;}
         if(K1==0&&K2==1&&K3==0){Q1=0;Q2=1;}
         if(K1==0&&K2==0&&K3==0){Q1=1;Q2=0;}
         if(K1==0&&K4==0)Q3=0;
         if(K1==0&&K4==1)Q3=1;
     void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
    flag=1;                                                         //中断溢出标志
   void  zd3()  interrupt 3                  //T1中断用来每50MS查询串口数据发送和接收
     unsigned char a,b;
         unsigned int c,d,e=0;
     unsigned char i=0;
         TH1=(65536-50000)/256;
         TL1=(65536-50000)%256;
c=hta(S);
send[5]=c>>8;
send[6]=(unsigned char)c;
d=0;
for(c=1;c<7;c++)d^=send[c];
d=hta(d);
send[7]=d>>8;
send[8]=(unsigned char)d;
while(e!=1)
if(RI)
a=SBUF;
RI=0;
if(a==0x40)i=0;
rec=a;
i++;
if(a==0x0d)
if(ath(rec[1],rec[2])==15)
b=0;
for(a=1;a if(b==ath(rec[i-3],rec[i-2]))
if((ath(rec[3],rec[4])&0x01)==0)
for(a=0;a<10;a++)
SBUF=send[a];
while(TI!=1);
TI=0;
else
for(a=0;a<8;a++)
SBUF=error[a];
while(TI!=1);
TI=0;
e=1;
else
TI=0;
/*         timer++;
         if(timer>=400)
          timer=0;
          TX=1;                                        //400MS  启动一次模块
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TX=0;
unsigned char ath(unsigned char a,unsigned char b)
if(a<0x40)a-=0x30;
else if(a<0x47)a-=0x37;
else if(a<67)a-=0x57;
if(b<0x40)b-=0x30;
else if(b<0x47)b-=0x37;
else if(b<67)b-=0x57;
return((a<<4)+b);
unsigned int hta(unsigned char a)
unsigned int b;
b=a>>4;
a&=0x0f;
if(a<0x0a)a+=0x30;
else a+=0x37;
if(b<0x0a)b+=0x30;
else b+=0x37;
b=((b<<8)+a);
return b;
void main(void)
        TMOD=0x11;                   //设T0为方式1,GATE=1;
        TH0=0;
        TL0=0;
        TH1=(65536-50000)/256;                   //50MS定时
        ET0=1;             //允许T0中断
    ET1=1;                                   //允许T1中断
        TR1=1;                           //开启定时器
        SCON=0x50;
    BRT=0xfd;
    AUXR=0x11;
    EA=1;         //开启总中断
        RI=0;TI=0;
    while(1)
         while(!RX);                //当RX为零时等待
         TR0=1;                            //开启计数
         while(RX);        //当RX为1计数并等待
         TR0=0;                                //关闭计数
     Conut();                        //计算
         timer++;
         if(timer>=400)
          timer=0;
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TX=0;
Display();
delay(2);
本文来自论坛,点击查看完整帖子内容。
全部作者的其他最新日志
发表评论 评论 (1 个评论)
回复 whywhy89713 2013-5-26 22:34
把原理图放出来,要不看起来太麻烦;你先看看你的数码管是不是共阳极的,这虽然是个很简单的地方,但还是有可能有错哦,要是共阴极就要用0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
