注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
tianbo1260的个人空间 https://home.eeworld.com.cn/space-uid-432489.html [收藏] [复制] [分享] [RSS]
日志
MSP430G2553串口连接12864显示,只用连接三个引脚,大大节省资源
已有 1156 次阅读2012-7-15 12:20 |
#include <msp430g2553.h>
#define uint unsigned int
#define uchar unsigned char
#define ulong unsigned long
unsigned char a[]={"波天神终于把12864学会了!"};
#define SID  BIT1
#define SCLK BIT2
#define CS   BIT3
#define LCDPORT P1OUT
#define SID_1  LCDPORT |= SID
#define SID_0  LCDPORT &= ~SID
#define SCLK_1 LCDPORT |= SCLK
#define SCLK_0 LCDPORT &= ~SCLK
#define CS_1   LCDPORT |= CS
#define CS_0   LCDPORT &= ~CS
void delay(unsigned char ms)
    unsigned char i,j;
    for(i=ms;i>0;i--)
    for(j=120;j>0;j--);
*名    称:LCD_Write_cmd()
*功    能:写一个命令到LCD12864
*入口参数:cmd:待写入的命令,无符号字节形式
*出口参数:无
*说    明:写入命令时,RW=0,RS=0 扩展成24位串行发送
*格    式:11111 RW0 RS 0   xxxx0000    xxxx0000
*          |最高的字节  |命令的bit7~4|命令的bit3~0|
void write_cmd(uchar cmd)
  uchar i,high4bits,low4bits;
  ulong lcdcmd;
  high4bits = cmd & 0xf0;
  low4bits =  cmd & 0x0f;
  lcdcmd=((ulong)0xf8<<16)+((ulong)high4bits<<8)+((ulong)low4bits<<4);
  CS_1;
  SCLK_0;
  for(i=0;i<24;i++)
    SID_0;
    if(lcdcmd & 0x00800000) SID_1;
    lcdcmd <<=1;
    delay(3);
    SCLK_1;
    delay(3);
    SCLK_0;
  CS_0;
*名    称:LCD_Write_Byte()
*功    能:向LCD12864写入一个字节数据
*入口参数:byte:待写入的字符,无符号形式
*出口参数:无
*范    例:LCD_Write_Byte('F') //写入字符'F'
void write_dat(uchar dat)
  ulong lcddat;
  high4bits = dat & 0xf0;
  low4bits =  dat & 0x0f;
  lcddat=((ulong)0xfa<<16)+((ulong)high4bits<<8)+((ulong)low4bits<<4);
  CS_1;
  SCLK_0;
  for(i=0;i<24;i++)
    SID_0;
    if(lcddat & 0x00800000) SID_1;
    lcddat <<=1;
    delay(3);
    SCLK_1;
    delay(3);
    SCLK_0;
  CS_0;
*名    称:LCD_pos()
*功    能:设置液晶的显示位置
*入口参数:x:第几行,1~4对应第1行~第4行
*          y:第几列,0~15对应第1列~第16列
*出口参数:无
*范    例:LCD_pos(2,3) //第二行,第四列
void lcd_pos(uchar x,uchar y)
  uchar pos;
  switch(x)
    case 1:pos=0x80;break;
    case 2:pos=0x90;break;
    case 3:pos=0x88;break;
    case 4:pos=0x98;break;
    default:pos=0x80;
  pos += y;
  write_cmd(pos);
//LCD12864初始化
void LCD_init(void)
    write_cmd(0x30);
    delay(5);
    write_cmd(0x0C);
    delay(5);
    write_cmd(0x01);
    delay(5);
     write_cmd(0x02);
    delay(5);
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  P1SEL=0x00;
  P1DIR = BIT1 + BIT2 + BIT3;
  LCD_init();
  delay(40);
  lcd_pos(1,0);
  write_dat(a[0]);
  write_dat(a[1]);
  write_dat(a[2]);
  write_dat(a[3]);
  write_dat(a[4]);
  write_dat(a[5]);
  write_dat(a[6]);
  write_dat(a[7]);
  write_dat(a[8]);
  write_dat(a[9]);
  write_dat(a[10]);
  write_dat(a[11]);
  lcd_pos(2,0);
  write_dat(a[12]);
  write_dat(a[13]);
  write_dat(a[14]);
  write_dat(a[15]);
  write_dat(a[16]);
  write_dat(' ');
  write_dat(a[17]);
  write_dat(a[18]);
  write_dat(a[19]);
  write_dat(a[20]);
  write_dat(a[21]);
  write_dat(a[22]);
  write_dat(a[23]);
  write_dat(a[24]);
  while(1)
  //return 0;
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
