使用过CC2530的朋友肯定对TI的片内温度不陌生;下面带来2538的片内温度读取;先看实验结果:
代码部分:选择使用TinyOS来实现此处的实验是向大家展示如何TinyOS如何直接使用C(h)文件,打消大家认为TiinyOS编程只能用nesC的误区
1,温度读取函数 tinyos-main-release_tinyos_2_1_2\tos\chips\cc2538\adc 下的cc2538_temp_sensor.c和cc2538_temp_sensor.h
cc2538_temp_sensor.h文件:
[cpp] view plaincopyprint?
- #ifndef CC2538_TEMP_SENSOR_H_
- #define CC2538_TEMP_SENSOR_H_
- #define CONST 0.58134 //(VREF / 2047) = (1190 / 2047), VREF from Datasheet
- #define OFFSET_DATASHEET_25C 827 // 1422*CONST, from Datasheet
- #define TEMP_COEFF (CONST * 4.2) // From Datasheet
- #define OFFSET_0C (OFFSET_DATASHEET_25C - (25 * TEMP_COEFF))
- uint16_t Get_CC2538_Temp(void);
- #endif
cc2538_temp_sensor.c文件:
- #include <stdbool.h>
- #include <stdint.h>
- #include <stdio.h>
- #include "hw_memmap.h"
- #include "gpio.h"
- #include "hw_ioc.h"
- #include "ioc.h"
- #include "interrupt.h"
- #include "adc.h"
- #include "sys_ctrl.h"
- #include "hw_sys_ctrl.h"
- #include "systick.h"
- #include "hw_rfcore_xreg.h"
- #include "hw_cctest.h"
- #include "cc2538_temp_sensor.h"
- uint16_t ui16Dummy;
- // Enable RF Core (needed to enable temp sensor)
- SysCtrlPeripheralEnable(SYS_CTRL_PERIPH_RFC);
- // Connect temp sensor to ADC
- HWREG(CCTEST_TR0) |= CCTEST_TR0_ADCTM;
- // Enable the temperature sensor
- HWREG(RFCORE_XREG_ATEST) = 0x01;
- // Configure ADC, Internal reference, 512 decimation rate (12bit)
- SOCADCSingleConfigure(SOCADC_12_BIT, SOCADC_REF_INTERNAL);
- // Trigger single conversion on internal temp sensor
- SOCADCSingleStart(SOCADC_TEMP_SENS);
- // Wait until conversion is completed
- while(!SOCADCEndOfCOnversionGet()){
- // Get data and shift down based on decimation rate
- ui16Dummy = SOCADCDataGet() >> SOCADC_12_BIT_RSHIFT;
- return ui16Dummy;
2,编写TinyOS例程:Adc_TempAppC.nc,Adc_TempC.nc,makefile文件:
makefile文件:
[plain] view plaincopyprint?
- COMPONENT=Adc_TempAppC
- CFLAGS += -DUSE_TIMER_HANDLER
- CFLAGS += -DNOT_USE_PRINTFC_BUT_USE_PRINT
- include $(MAKERULES)
Adc_TempAppC.nc文件
- configuration Adc_TempAppC
- implementation
- components MainC, Adc_TempC;
- components new TimerMilliC() as Timer1;
- Adc_TempC -> MainC.Boot;
- Adc_TempC.Timer1 -> Timer1;
Adc_TempC.nc文件:
- *实验附加----CC2538片内温度读取
- *节点需求数1
- *编译命令make cc2538cb
- #include "Timer.h"
- #include "printf.h"
- module Adc_TempC
- uses interface Timer<TMilli> as Timer1;
- uses interface Boot;
- implementation
- task void time1_Task();
- uint16_t ui16Dummy=0;
- *启动事件
- event void Boot.booted()
- /**开启一秒的周期性定时器(单位毫秒) Timer1**/
- call Timer1.startPeriodic( 1000 );
- *任务time1_Task
- double dOutputVoltage;
- ui16Dummy = Get_CC2538_Temp();
- printf("ADC raw readout: %d\n", ui16Dummy);
- //温度计算
- dOutputVoltage = ui16Dummy * CONST;
- dOutputVoltage = ((dOutputVoltage - OFFSET_0C) / TEMP_COEFF);
- ui16Dummy = dOutputVoltage * 10;
- printf("Temperature: %d", ui16Dummy/10);
- printf(".%d", ui16Dummy%10);
- printf(" C\n");
- *Timer1定时时间到事件
- event void Timer1.fired()
- /****提交time1_Task任务***/
- post time1_Task();
大家可以看到Adc_TempC.nc文件中
这些不就是直接使用了C文件了吗?nesC只是C的方言,相信即使没有nesC语言基础的朋友应该也能大概看懂代码干了什么;就是1秒采集一次片内温度然后串口打印
至此可以引申如果是需要给TinyOS引入其他的传感器呢,呵呵,其实就是拿来厂家提供的C源码直接使用即可,不用去写成nesC;
本文来自论坛,点击查看完整帖子内容。
