注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
wo4fisher的个人空间 https://home.eeworld.com.cn/space-uid-296469.html [收藏] [复制] [分享] [RSS]
日志
【得捷Follow me第4期】W5500-EVB-Pico PIO下TCP协议实现Webclient和WebServer
已有 323 次阅读2024-3-2 15:30 |个人分类:W5500-EVB-Pico
1. 准备工作
新建基础工程,并添加Ethernet3库到工程中
2. WebClient测试
#include <Arduino.h>
#include <SPI.h>
#include <Ethernet3.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "www.baidu.com";    // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 2, 177);
IPAddress myDns(192, 168, 2, 1);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Variables to measure the speed
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true;  // set to false for better speed measurement
uint8_t svrIp[4]= {0};
void setup() {
  // Open serial communications and wait for port to open:
  Serial.begin(115200);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Ethernet.setCsPin(17);
  Ethernet.setRstPin(20);
  // start the Ethernet connection:
  Serial.println("Initialize Ethernet with DHCP:");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // Check for Ethernet hardware link status
    if (Ethernet.link() == 0) {
      Serial.println("Ethernet cable is not connected.");
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip, myDns);
  } else {
    Serial.print("  DHCP assigned IP ");
    Serial.println(Ethernet.localIP());
  // give the Ethernet shield a second to initialize:
  delay(1000);
  Serial.print("connecting to ");
  Serial.print(server);
  Serial.println("...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.print("connected to ");
    client.remoteIP(svrIp);
    Serial.print(svrIp[0]);Serial.print(',');
    Serial.print(svrIp[1]);Serial.print(',');
    Serial.print(svrIp[2]);Serial.print(',');
    Serial.print(svrIp[3]);Serial.println();
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host: www.baidu.com");
    client.println("Connection: close");
    client.println();
  } else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  beginMicros = micros();
void loop() {
  // if there are incoming bytes available
  // from the server, read them and print them:
  int len = client.available();
  if (len > 0) {
    byte buffer[80];
    if (len > 80) len = 80;
    client.read(buffer, len);
    if (printWebData) {
      Serial.write(buffer, len); // show in the serial monitor (slows some boards)
    byteCount = byteCount + len;
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    endMicros = micros();
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    Serial.print("Received ");
    Serial.print(byteCount);
    Serial.print(" bytes in ");
    float seconds = (float)(endMicros - beginMicros) / 1000000.0;
    Serial.print(seconds, 4);
    float rate = (float)byteCount / seconds / 1000.0;
    Serial.print(", rate = ");
    Serial.print(rate);
    Serial.print(" kbytes/second");
    Serial.println();
    // do nothing forevermore:
    while (true) {
      delay(1);
实现过程:
第一步:定义mac地址、W5500 静态ip地址、DNS地址和web服务器主机ip名称。
第二步:定义EthernetClient。
第三步:在初始化函数setup中完成cs引脚和rst引脚的配置,调用begin函数完成W5500网络参数初始化(首先尝试动态分配,动态分配失败的话,使用静态分配方式进行初始化),接下来调用connect方法连接远端服务器。
第四步:在循环函数Loop中,当接收到返回数据,通过串口打印;断开连接的话,停止。
3. WebServer测试
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
