注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
mameng的个人空间 http://home.eeworld.com.cn/space-uid-440926.html [收藏] [复制] [分享] [RSS]
日志
[复旦微FM33LG0系列开发板测评] 驱动RGB TFT显示屏
已有 413 次阅读2021-12-21 23:22
     今天冬至,看到朋友圈都在吃饺子。想写个祝福大家冬至的话题。手里有个中景园电子技术有限公司320RGB*480 dots matrix TFT LCD 模块,想用FM33LG0驱动一下:
   PIN定义:
逻辑时序图:
  普通口模拟:
void LCD_GPIO_Init(void)
	FL_GPIO_InitTypeDef GPIO_InitStruct = {0};
    FL_GPIO_ResetOutputPin(GPIOA, FL_GPIO_PIN_0|FL_GPIO_PIN_1|FL_GPIO_PIN_2|FL_GPIO_PIN_3|FL_GPIO_PIN_4|FL_GPIO_PIN_5|FL_GPIO_PIN_6|FL_GPIO_PIN_7);
    GPIO_InitStruct.pin = FL_GPIO_PIN_0|FL_GPIO_PIN_1|FL_GPIO_PIN_2|FL_GPIO_PIN_3|FL_GPIO_PIN_4|FL_GPIO_PIN_6|FL_GPIO_PIN_7;
    GPIO_InitStruct.mode = FL_GPIO_MODE_OUTPUT;
    GPIO_InitStruct.outputType = FL_GPIO_OUTPUT_PUSHPULL;
    GPIO_InitStruct.pull = FL_DISABLE;
    FL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    FL_GPIO_ResetOutputPin(GPIOB, FL_GPIO_PIN_5);
    GPIO_InitStruct.pin = FL_GPIO_PIN_5;
    GPIO_InitStruct.mode = FL_GPIO_MODE_INPUT ;
    FL_GPIO_Init(GPIOB, &GPIO_InitStruct);
// 	GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_6|GPIO_Pin_7);
#define LCD_SCLK_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_0)//SCL=SCLK
#define LCD_SCLK_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_0)
#define LCD_MOSI_Clr() FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_1)//SDA=MOSI
#define LCD_MOSI_Set() FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_1)
#define LCD_RES_Clr()  FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_2)//RES
#define LCD_RES_Set()  FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_2)
#define LCD_DC_Clr()   FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_3)//DC
#define LCD_DC_Set()   FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_3)
#define LCD_BLK_Clr()  FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_4)//BLK
#define LCD_BLK_Set()  FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_4)
#define ZK_MISO        FL_GPIO_ReadInputPort(GPIOB)//MISO  读取字库数据引脚
//                       	GPIO_ReadInputDataBit
//GPIO_ResetBits
#define LCD_CS_Clr()   FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_6)//CS
#define LCD_CS_Set()   FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_6)
#define ZK_CS_Clr()     FL_GPIO_ResetOutputPin(GPIOA,FL_GPIO_PIN_7)
#define ZK_CS_Set()     FL_GPIO_SetOutputPin(GPIOA,FL_GPIO_PIN_7)
驱动代码:
#include "lcd_init.h"
      函数说明:LCD串行数据写入函数
      入口数据:dat  要写入的串行数据
      返回值:  无
void LCD_Writ_Bus(u8 dat)
	u8 i;
	LCD_CS_Clr();
	for(i=0;i<8;i++)
		LCD_SCLK_Clr();
		if(dat&0x80)
		   LCD_MOSI_Set();
		else
		   LCD_MOSI_Clr();
		LCD_SCLK_Set();
		dat<<=1;
  LCD_CS_Set();
      函数说明:LCD写入数据
      入口数据:dat 写入的数据
      返回值:  无
void LCD_WR_DATA8(u8 dat)
	LCD_Writ_Bus(dat);
      函数说明:LCD写入数据
      入口数据:dat 写入的数据
      返回值:  无
void LCD_WR_DATA(u32 dat)
	LCD_Writ_Bus(dat>>16);
	LCD_Writ_Bus(dat>>8);
	LCD_Writ_Bus(dat);
      函数说明:LCD写入命令
      入口数据:dat 写入的命令
      返回值:  无
void LCD_WR_REG(u8 dat)
	LCD_DC_Clr();//写命令
	LCD_Writ_Bus(dat);
	LCD_DC_Set();//写数据
      函数说明:设置起始和结束地址
      入口数据:x1,x2 设置列的起始和结束地址
                y1,y2 设置行的起始和结束地址
      返回值:  无
void LCD_Address_Set(u16 x1,u16 y1,u16 x2,u16 y2)
	LCD_WR_REG(0x2a);//列地址设置
	LCD_WR_DATA8(x1>>8);
	LCD_WR_DATA8(x1);
	LCD_WR_DATA8(x2>>8);
	LCD_WR_DATA8(x2);
	LCD_WR_REG(0x2b);//行地址设置
	LCD_WR_DATA8(y1>>8);
	LCD_WR_DATA8(y1);
	LCD_WR_DATA8(y2>>8);
	LCD_WR_DATA8(y2);
	LCD_WR_REG(0x2c);//储存器写
void LCD_Init(void)
	LCD_GPIO_Init();//初始化GPIO
	LCD_RES_Clr();//复位
	FL_DelayMs(100);
	LCD_RES_Set();
	FL_DelayMs(100);
	LCD_BLK_Set();//打开背光
  FL_DelayMs(100);
	//************* Start Initial Sequence **********//
	LCD_WR_REG(0x11); //Sleep out
	FL_DelayMs(120);              //Delay 120ms
	LCD_WR_REG(0XF2);
	LCD_WR_DATA8(0x18);
	LCD_WR_DATA8(0xA3);
	LCD_WR_DATA8(0x12);
	LCD_WR_DATA8(0x02);
	LCD_WR_DATA8(0XB2);
	LCD_WR_DATA8(0x12);
	LCD_WR_DATA8(0xFF);
	LCD_WR_DATA8(0x10);
	LCD_WR_DATA8(0x00);
	LCD_WR_REG(0XF8);
	LCD_WR_DATA8(0x21);
	LCD_WR_DATA8(0x04);
	LCD_WR_REG(0X13);
	LCD_WR_REG(0x36);    // Memory Access Control
	if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x08);
	else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC8);
	else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x78);
	else LCD_WR_DATA8(0xA8);
	LCD_WR_REG(0xB4);
	LCD_WR_DATA8(0x02);
	LCD_WR_REG(0xB6);
	LCD_WR_DATA8(0x02);
	LCD_WR_DATA8(0x22);
	LCD_WR_REG(0xC1);
	LCD_WR_DATA8(0x41);
	LCD_WR_REG(0xC5);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x18);
	LCD_WR_REG(0x3a);
	LCD_WR_DATA8(0x66);
	FL_DelayMs(50);
	LCD_WR_REG(0xE0);
	LCD_WR_DATA8(0x0F);
	LCD_WR_DATA8(0x1F);
	LCD_WR_DATA8(0x1C);
	LCD_WR_DATA8(0x0C);
	LCD_WR_DATA8(0x0F);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x48);
	LCD_WR_DATA8(0x98);
	LCD_WR_DATA8(0x37);
	LCD_WR_DATA8(0x0A);
	LCD_WR_DATA8(0x13);
	LCD_WR_DATA8(0x04);
	LCD_WR_DATA8(0x11);
	LCD_WR_DATA8(0x0D);
	LCD_WR_DATA8(0x00);
	LCD_WR_REG(0xE1);
	LCD_WR_DATA8(0x0F);
	LCD_WR_DATA8(0x32);
	LCD_WR_DATA8(0x2E);
	LCD_WR_DATA8(0x0B);
	LCD_WR_DATA8(0x0D);
	LCD_WR_DATA8(0x05);
	LCD_WR_DATA8(0x47);
	LCD_WR_DATA8(0x75);
	LCD_WR_DATA8(0x37);
	LCD_WR_DATA8(0x06);
	LCD_WR_DATA8(0x10);
	LCD_WR_DATA8(0x03);
	LCD_WR_DATA8(0x24);
	LCD_WR_DATA8(0x20);
	LCD_WR_DATA8(0x00);
	LCD_WR_REG(0x11);
	FL_DelayMs(120);
	LCD_WR_REG(0x29);
	LCD_WR_REG(0x2C);
main
Display_GB2312_String(10,50,32, "祝大家冬至吃水饺",WHITE,BLACK);
		 Display_GB2312_String(10,100,32, "祝大家冬至吃水饺",RED,BLACK);
		Display_GB2312_String(10,150,32, "祝大家冬至吃水饺",BLUE,BLACK);
		Display_GB2312_String(10,200,32, "祝大家冬至吃水饺",GREEN,BLACK);
效果如下:
测试视频:
总结:库函数跟STM32命名和其他底层驱动略有不同,需要耐心细致。
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
