【国民技术N32WB031_STB开发板评测】创建MDK模版
1、在这篇创建的基础上,复制这个模版,重命名为N32WB_KEY。并在bsp文件夹下新建key、led两个文件夹,添加好key.c、key.h、led.c、led.h。目录如下:
├─key
│ key.c
│ key.h
├─led
│ led.c
│ led.h
2、用mdk打开工程,把创建bsp/LED\bsp/key分组,并把.c\.h添加进工程:
3、led.c程序如下:
#include "led.h"
* @brief Configures LED GPIO.
* @param GPIOx x can be A to G to select the GPIO port.
* @param Pin This parameter can be GPIO_PIN_0~GPIO_PIN_15.
void LedInit(GPIO_Module* GPIOx, uint16_t Pin)
GPIO_InitType GPIO_InitStructure;
/* Check the parameters */
assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
/* Enable the GPIO Clock */
if (GPIOx == GPIOA)
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
else if (GPIOx == GPIOB)
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
else
return;
/* Configure the GPIO pin */
if (Pin <= GPIO_PIN_ALL)
GPIO_InitStruct(&GPIO_InitStructure);
GPIO_InitStructure.Pin = Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitPeripheral(GPIOx, &GPIO_InitStructure);
* @brief Turns selected Led on.
void LedOn(GPIO_Module *GPIOx, uint16_t Pin)
GPIO_SetBits(GPIOx, Pin);
* @brief Turns selected Led Off.
void LedOff(GPIO_Module* GPIOx, uint16_t Pin)
GPIO_ResetBits(GPIOx, Pin);
* @brief Toggles the selected Led.
void LedBlink(GPIO_Module* GPIOx, uint16_t Pin)
GPIO_TogglePin(GPIOx, Pin);
led.h:
#ifndef __LED_H__
#define __LED_H__
#include "n32wb03x.h"
void LedInit(GPIO_Module* GPIOx, uint16_t Pin);
void LedOn(GPIO_Module *GPIOx, uint16_t Pin);
void LedOff(GPIO_Module* GPIOx, uint16_t Pin);
void LedBlink(GPIO_Module* GPIOx, uint16_t Pin);
#endif
key.c:
#include "key.h"
#include "led.h"
#include "main.h"
* @brief Configures key port.
void KeyInputExtiInit(GPIO_Module* GPIOx, uint16_t Pin)
EXTI_InitType EXTI_InitStructure;
NVIC_InitType NVIC_InitStructure;
if (GPIOx == GPIOA)
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_AFIO, ENABLE);
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB | RCC_APB2_PERIPH_AFIO, ENABLE);
else
return;
/*Configure the GPIO pin as input floating*/
GPIO_InitStructure.GPIO_Pull = GPIO_PULL_UP;
/*Configure key EXTI Line to key input Pin*/
GPIO_ConfigEXTILine(KEY_INPUT_PORT_SOURCE, KEY_INPUT_PIN_SOURCE);
/*Configure key EXTI line*/
EXTI_InitStructure.EXTI_Line = KEY_INPUT_EXTI_LINE;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; // EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_InitPeripheral(&EXTI_InitStructure);
/*Set key input interrupt priority*/
NVIC_InitStructure.NVIC_IRQChannel = KEY_INPUT_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
ke.y:
#ifndef __KEY_H__
#define __KEY_H__
void KeyInputExtiInit(GPIO_Module* GPIOx, uint16_t Pin);
#endif
4、在n32wb03_it.c中添加按键中断程序:
void EXTI2_3_IRQHandler(void)
if (RESET != EXTI_GetITStatus(KEY_INPUT_EXTI_LINE))
if(GPIO_ReadInputDataBit(KEY_INPUT_PORT, KEY_INPUT_PIN) == RESET)
Delay(10);
LedBlink(LED2_PORT, LED2_PIN);
EXTI_ClrITPendBit(KEY_INPUT_EXTI_LINE);
【注】这里只是演示所用,不能在实际项目中运行
然后在主程序里初始化key\led
#include "led.h"
#include "key.h"
int main(void)
LedInit(LED1_PORT, LED1_PIN);
LedInit(LED2_PORT, LED2_PIN);
LedOn(LED1_PORT, LED1_PIN);
LedOn(LED2_PORT, LED2_PIN);
KeyInputExtiInit(KEY_INPUT_PORT, KEY_INPUT_PIN);
while (1)
LedBlink(LED1_PORT, LED1_PIN);
Delay(0x28FFFF);
这样就可以实现LED1的周期闪烁,当按下Button1时翻转LED2【注】由于在中断中用了延时,所以效果不是很好,等讲了定时器,会进行优化。
