注册 登录
电子工程世界-论坛 返回首页 EEWORLD首页 频道 EE大学堂 下载中心 Datasheet 专题
lugl4313820的个人空间 http://home.eeworld.com.cn/space-uid-1269709.html [收藏] [复制] [分享] [RSS]
日志
【国民技术N32G430】LCD-ST7735
已有 289 次阅读2022-9-16 21:29
【目的】SPI驱动ST7735LCD屏
1、定义ST7735驱动IO:
              GND   电源地
              VCC   3.3v电源
              SCL   PA5(SCLK)
              SDA   PA7(MOSI)
              RES   PA3
              DC    PA2
              CS    PA4
              BLK   PA
3、宏定义相关IO,及电平转换等:
#define SPI_MASTER                SPI1
#define SPI_MASTER_PERIPH         RCC_APB2_PERIPH_SPI1
#define SPI_MASTER_PERIPH_GPIO    RCC_AHB_PERIPH_GPIOA
#define SPI_MASTER_GPIO           GPIOA
#define SPI_MASTER_GPIO_ALTERNATE GPIO_AF1_SPI1
#define SPI_MASTER_MISO_PIN       GPIO_PIN_6
#define SPI_MASTER_MOSI_PIN       GPIO_PIN_7
#define SPI_MASTER_CLK_PIN        GPIO_PIN_5
#define SPI_MASTER_NSS_PIN        GPIO_PIN_4
#define LCD_RES_PIN               GPIO_PIN_3
#define LCD_DC_PIN                GPIO_PIN_2
#define LCD_BLK_PIN               GPIO_PIN_1
#define LCD_SCLK_Clr()   GPIO_Pins_Reset(GPIOA,SPI_MASTER_CLK_PIN)
#define LCD_SCLK_Set()   GPIO_Pins_Set(GPIOA,SPI_MASTER_CLK_PIN)
#define LCD_MOSI_Clr()   GPIO_Pins_Reset(GPIOA,SPI_MASTER_MOSI_PIN)
#define LCD_MOSI_Set()   GPIO_Pins_Set(GPIOA,SPI_MASTER_MOSI_PIN)
#define LCD_CS_Clr()   GPIO_Pins_Reset(GPIOA,SPI_MASTER_NSS_PIN)
#define LCD_CS_Set()   GPIO_Pins_Set(GPIOA,SPI_MASTER_NSS_PIN)
#define LCD_RES_Clr()   GPIO_Pins_Reset(GPIOA,LCD_RES_PIN)
#define LCD_RES_Set()   GPIO_Pins_Set(GPIOA,LCD_RES_PIN)
#define LCD_DC_Clr()    GPIO_Pins_Reset(GPIOA,LCD_DC_PIN)
#define LCD_DC_Set()    GPIO_Pins_Set(GPIOA,LCD_DC_PIN)
#define LCD_BLK_LOW()   GPIO_Pins_Reset(GPIOA,LCD_BLK_PIN)
#define LCD_BLK_Set()   GPIO_Pins_Set(GPIOA,LCD_BLK_PIN)
#define USE_HORIZONTAL 2  //设置横屏或者竖屏显示 0或1为竖屏 2或3为横屏
#if USE_HORIZONTAL==0||USE_HORIZONTAL==1
    #define LCD_W 128  //0x80
    #define LCD_H 160  //0xA0
#else
    #define LCD_W 160
    #define LCD_H 128
#endif
4、时钟初始化:
void RCC_Configuration(void)
    /* PCLK2 = HCLK/2 */
    RCC_Pclk2_Config(RCC_HCLK_DIV2);
    /* Enable peripheral clocks --------------------------------------------------*/
    /* spi clock enable */
    RCC_APB2_Peripheral_Clock_Enable(SPI_MASTER_PERIPH );
    /* GPIO Periph clock enable */
    RCC_AHB_Peripheral_Clock_Enable(SPI_MASTER_PERIPH_GPIO );
5、IO、SPI初始化:
void LCD_GPIO_Init(void)
    GPIO_InitType GPIO_InitStructure;
    SPI_InitType SPI_InitStructure;
    GPIO_Structure_Initialize(&GPIO_InitStructure);
    GPIO_InitStructure.Pin = SPI_MASTER_NSS_PIN | LCD_RES_PIN | LCD_DC_PIN | LCD_BLK_PIN;
    GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_OUT_PP;
		/* Set the pin drive current to 4MA*/
		GPIO_InitStructure.GPIO_Current = GPIO_DS_4MA;
		/* Initialize GPIO */
		GPIO_Peripheral_Initialize(GPIOA, &GPIO_InitStructure);
#if SOFTWARE_SPI_ENABLE
    /* Configure master pins: NSS, SCK, MISO and MOSI */
    /* Confugure SPI pins as Alternate Function Push Pull */
    GPIO_InitStructure.Pin        = SPI_MASTER_MOSI_PIN | SPI_MASTER_CLK_PIN ;
    GPIO_InitStructure.GPIO_Mode  = GPIO_MODE_AF_PP;
    GPIO_InitStructure.GPIO_Slew_Rate = GPIO_SLEW_RATE_FAST;
    GPIO_InitStructure.GPIO_Alternate = SPI_MASTER_GPIO_ALTERNATE;
    GPIO_Peripheral_Initialize(SPI_MASTER_GPIO, &GPIO_InitStructure);
    SPI_Initializes_Structure(&SPI_InitStructure);
    SPI_InitStructure.DataDirection = SPI_DIR_SINGLELINE_TX;
    SPI_InitStructure.SpiMode       = SPI_MODE_MASTER;
    SPI_InitStructure.DataLen       = SPI_DATA_SIZE_16BITS;
    SPI_InitStructure.CLKPOL        = SPI_CLKPOL_LOW;
    SPI_InitStructure.CLKPHA        = SPI_CLKPHA_SECOND_EDGE;
    SPI_InitStructure.NSS           = SPI_NSS_SOFT;
    /* It is recommended that the SPI master mode of the C version chips should not exceed 18MHz */
    SPI_InitStructure.BaudRatePres  = SPI_BR_PRESCALER_8;
    SPI_InitStructure.FirstBit      = SPI_FB_MSB;
    SPI_InitStructure.CRCPoly       = 7;
    SPI_Initializes(SPI_MASTER, &SPI_InitStructure);
    SPI_NSS_Config(SPI_MASTER, SPI_NSS_SOFT);
    SPI_SS_Output_Enable(SPI1);
    /* Enable SPI_MASTER */
    SPI_ON(SPI_MASTER);
#else
#endif
6、写一个字节函数:
      函数说明:LCD串行数据写入函数
      入口数据:dat  要写入的串行数据
      返回值:  无
void LCD_Writ_Bus(uint8_t dat)
  LCD_CS_Clr();
     while((SPI1->STS & SPI_I2S_FLAG_TE) == RESET);//等待发送区空
     SPI_I2S_Data_Transmit(SPI1, dat);
  SysTick_Delay_Us(10);
  LCD_CS_Set();
#else
  uint8_t i;
    LCD_CS_Clr();
    for(i=0;i<8;i++)
        LCD_SCLK_Clr();
        if(dat&0x80)
           LCD_MOSI_Set();
        else
           LCD_MOSI_Clr();
        LCD_SCLK_Set();
        dat<<=1;
  LCD_CS_Set();
#endif
好了移植的主动驱动写好了,其他的函数见附件。
7、在main.c中初始化LCD,并显示出来:
本文来自论坛,点击查看完整帖子内容。
评论 (0 个评论)
facelist doodle 涂鸦板
您需要登录后才可以评论 登录 | 注册
热门文章
