【GD32F310G-START】HELLO WORLD - GD32 MCU - 电子工程世界-论坛 (eeworld.com.cn)
【GD32F310G-START】OLED之HELLO EEWORLD——硬件I2C - GD32 MCU - 电子工程世界-论坛
【新提醒】【GD32F310G-START】SPI驱动ST7735 - GD32 MCU - 电子工程世界-论坛 (eeworld.com.cn)
调好模拟SPI驱动st7735后,花点时间驱动硬件spi。改动的地方就是加上spi的驱动:
1、GPIO 、SPI初始化
#define SOFTWARE_SPI_ENABLE 0 //条件编译:0为硬件SPI 1为模拟SPI
void LCD_GPIO_Init(void)
spi_parameter_struct spi_init_struct;
rcu_periph_clock_enable(RCU_GPIOA);
rcu_periph_clock_enable(RCU_SPI0);
#if SOFTWARE_SPI_ENABLE //如果是模拟
gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7 | GPIO_PIN_4);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7 | GPIO_PIN_4);
gpio_bit_set(GPIOA, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7 | GPIO_PIN_4);
#else //如果是硬件
gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 );
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 );
gpio_bit_set(GPIOA, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 );
/* SPI0 GPIO configuration: NSS/PA4 */
gpio_mode_set(GPIOA, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_4 );
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
/* configure SPI0 GPIO: SCK/PA5, MISO/PA6, MOSI/PA7 */
gpio_af_set(GPIOA, GPIO_AF_0, GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7);
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7);
/* deinitilize SPI and the parameters */
spi_i2s_deinit(SPI0);
spi_struct_para_init(&spi_init_struct);
/* configure SPI0 parameter */
spi_init_struct.trans_mode = SPI_TRANSMODE_FULLDUPLEX;
spi_init_struct.device_mode = SPI_MASTER;
spi_init_struct.frame_size = SPI_FRAMESIZE_8BIT;
spi_init_struct.clock_polarity_phase = SPI_CK_PL_HIGH_PH_1EDGE;
spi_init_struct.nss = SPI_NSS_SOFT;
spi_init_struct.prescale = SPI_PSC_2;
spi_init_struct.endian = SPI_ENDIAN_MSB;
spi_init(SPI0, &spi_init_struct);
spi_enable(SPI0);
#endif
2、数据发送的修改:
函数说明:LCD串行数据写入函数
入口数据:dat 要写入的串行数据
返回值: 无
void LCD_Writ_Bus(uint8_t dat)
uint8_t i;
LCD_CS_Clr();
for(i=0;i<8;i++)
LCD_SCLK_Clr();
if(dat&0x80)
LCD_MOSI_Set();
else
LCD_MOSI_Clr();
LCD_SCLK_Set();
dat<<=1;
#else
// while(RESET == spi_i2s_flag_get(SPI0, SPI_FLAG_TBE));
spi_i2s_data_transmit(SPI0,dat);
delay_1us(1); //【特别注意这里要加上1微秒的延时,要不死活不显示】
#endif
LCD_CS_Set();
最后与模拟对比了一下,感觉速度没有什么驱别。是不是还有哪里没有弄对。大佬、前辈们指点一下。
